Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: Champion 190
    Mar 2018
    NJ
    Champion 190
    So i purchased a 1998 champion 190 fish & ski with a mercury 200 efi about a month ago. Like the design of the boat a lot,the gentleman i purchased it from said it runs 70mph. I am doing some winter mods to motor-heads/tuner/reeds/6 inch set back. Looking for feedback of anyone who has owned or ran this style boat. Thank you
    Pekin, IL
    5 Post(s)
    I have owned several Champions and currently have Champion Swift. Very good, easy to drive boats. Only issue I have seen is the transoms can be iffy so keep an eye on it. Well built boat that should give you good service.
    Rock
    Team Junk
    Dec 2017
    sam rayburn lake...east texas
    I live on sam rayburn and I live n my champion come springtime 18.6 1999 in very good condition just put a new power head on it 7 pedal 91 .030 short ex boyesen reeds stacks C-4 heads still running the wmh -31 carbs I have some Wh-20 on the way and a jack P I only have about 3 hr on the motor been taking it EZ but I love the old Champs tops n my book Click image for larger version.
ID:	424740Click image for larger version.
    Nov 2016
    Missouri
    I have a 1995 190 dual console champion with a 200xri efi turning a 25 tempest plus 8" rapid jack jackplate and only running 63 mph gps with full tank fuel and all fishing gear and 2 guys. Prop slip is around 16-17% slip i need to get prop worked on. I have a 1989 176 champ also.
    Daddy taught me to never force anything but to just get a bigger hammer.
    1995 19'0" Champion bass boat
    1995 200 XRI
    Feb 2017
    Wixom lake michigan
    I have a 202 Champion and love the boat, have had it almost 16 years. Keep the transom sealed up good, no other issues at all, great boats. 70 mph is probably optimistic, guessing that is speedo reading. Setup right im guessing 65ish, and should be easy to drive at those speeds. Rough water ride is simply amazing imho
    Nov 2016
    Missouri
    The 1995 and 1996 202's where the faster ones as they where the skinny ones, friend has a 202 with a 200 on it and it will run 69 gps by himself and loaded light. Loaded and 2 people he runs around 65 gps. Yea im told it should be around 66 to 68 loaded on my 190.
    1995 200 XRI
    Feb 2017
    Wixom lake michigan
    Mine is a 97 model, approx 92 inch beam. I have a stock 225efi 3 litre, pushes it 77-78 light fishing load. Best prop by far is a 27p. t-1 yamaha worked by mark croxton
    Nov 2016
    Missouri
    My 190 is 92 inch beam, im running a stock out of the box 25 tempest and have lots of prop slip and it will eventually get sent off to be worked. Im still working bugs out of motor and setup, last time out tach stopped working so put new tach in and haven't been back out.
    1995 200 XRI
    Feb 2017
    Wixom lake michigan
    Water is hard here....will probably be end of march at the earliest for my next ride
    Mar 2018
    NJ
    I was hoping to get some feedback on motor height. How much Above or Below the pad
    Nov 2016
    Missouri
    Start at 3 1/2 inches prop to pad and go from there either up or down and watch water pressure if you go up. You can go up till either you lose speed and or water pressure but the is no set of numbers for any boat as mine would run different prop to pad than yours.
    1995 200 XRI
  12. #12
    Feb 2017
    Wixom lake michigan
    Yup, mine likes 3 1/4, below pad, with 10" setback. I lost bite before water pressure when going up. I dont have low water pickups
  13. #13
    Mar 2018
    NJ
    I have a cle lower unit that i am going to swap out as part of my upgrades.
  14. #14
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by JasonRS View Post
    That seems deep with that much setback. What prop are you running?
    Josh Peterson
  15. #15
    Nov 2016
    Missouri
    I think im somewhere around 3 1/2- 3 3/4 inch prop to pad with an 8 inch plate.
    1995 200 XRI
  1. New guy with a 95 200 xri on 201 Champion
    By jdmitchell in forum Bass Boats and Sport Fishing Rigs
    Last Post: 03-02-2015, 11:32 AM
  2. Champion 223
    By Rhoran in forum Bass Boats and Sport Fishing Rigs
    Last Post: 08-16-2013, 04:28 PM
  3. need some set up help on a Champion
    By hwyrnr in forum Technical Discussion
    Last Post: 01-20-2005, 08:07 PM
  4. Champion.....LOL!
    By FCnLa in forum Technical Discussion
    Last Post: 11-12-2002, 03:56 AM
