Results 16 to 30 of 32
12-02-2018, 08:40 PM #16Supporting Vendor
- 11,838
- 163
- 11
- 795
I’m building a 2.5 225 PM this week that was decked .009” on both banks customer bought this motor from a buddy , I built the motor in 2012 , has .030” top pinned Vertex pistons installed , motor was initially built with 1.25 mm thick head gaskets and ran fine , the port side had some issues that I don’t know what , the original owner didn’t notice the .009” stamped VERY prominently on the side of the block next to the deck , he inadvertently installed a 1.00 mm head gasket popped #2 took out gasket as well as the parent metal around sleeve that will have to have a flanged sleeve installed to repair the issue. I’m going to install a new set of pistons and plan on fly cutting the new pistons BEFORE I have Marles top pin them , I’ve tried to fly cut a set of pistons years ago that was top pinned and wasn’t real successful that tooling cuts the aluminum piston like butter BUT when the tooling contacts the hardened pin sh** hits the fan , just food for thought ... If your in doubt take a piece of soft solder bend a crook and install in a plug hole to reach the squish band area , turn the motor through and slowly allow the piston to crush the solder remove and measure it , my danger distance is less than .044” , anything less created by a cut deck will make me go to a thicker head gasket ...Good luck !
Jay @ JSRELast edited by Jay Smith; 12-02-2018 at 08:46 PM.
Jay @ JSRE
Capt.Insane-o liked this post
12-02-2018, 08:50 PM #17Supporting Vendor
- 11,838
- 163
- 11
- 795
BTW a deck mike answers a magnitude of questions before you install heads about your blocks deck height !! Most older blocks if not has been decked will render a piston Max .004” petruding out of the deck or .004” below deck , unless you have one of the newer blocks that has the block casted to use a flat O ring head this one at TDC stroke on the crank the piston will come .044” from the top of the block , this creates a safe squish with the totally flat head with only a combustion machined but no squish area furnished ..
Good luck ,
JayLast edited by Jay Smith; 12-03-2018 at 07:08 AM.
Jay @ JSRE
12-04-2018, 07:41 PM #185000 RPM
- Apr 2010
- Northern wis.
- 220
- 7
- 52
Jay, Not to steal this thread but I have a new to me 280 that has over .070 in the squish area. Knowing that your danger area is less than .044 but what is the # that is to much squish? Thanks
12-05-2018, 05:56 AM #19Supporting Vendor
- 11,838
- 163
- 11
- 795
O ringed heads indeed can have more squish nothing you can do , my comment was to warn about an absolute tight tolerance condition that at high rpms can cause contact piston to head causing ring land clearance to reduce preventing the rings from “breathing” causing engine failure and if enough contact can bend rods and could cause crank con rod bearing failure ... My suggestion is to ( if available ) use a deck mike to confirm deck / piston position, most garloc style gasket compression fire ring can be measured , with these two known dimensions the assembler can go together with certainty of a safe clearances..
Good luck,
JayJay @ JSRE
12-05-2018, 03:41 PM #20
It's not one person's thread to steal , it belongs to everyone. And you proved my point about , maybe clipping the OP's block .014 might not be A BAD THING IF THAT'S WHAT ACTUALLY HAPPENED ! If he has the same deal as your's .070-.014= .056 still shy of making the cover your azz minimum of .044 ..
Keep in mind that when measuring 2.5's that they have top guided rods (most of em) and if they are being checked while upright and you are turning them over by hand, the rod will droop down to the crank cheek and cock the piston in the bore. Tight on the botton, loose at the top. Brendon Powers makes a slick deck bridge with two gauges for those who don't want to measure one side then the other and split the difference to establish true deck clearance.
nitro_rat thanked for this post
12-05-2018, 05:42 PM #21Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1977
ChaZ... YOUR RITE ONN ROD DROP... tHE WAYYY THWEY THE BORE IS SLOPPY MORE CRANK WOES YOU WILL LIVE....IF IT IS TIGHT IF NOT BOTTOM GUILDED......I DID THIS 30 YEARS AGO......44 CID TOP G AND LET HER LOUSER/..... JUST SAYING....
12-05-2018, 05:49 PM #22Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1977
jUST TO SAY .... SOME THING HAS TO KEEP THE ROD STRAIGHT... CRANK CHEEK OR PISTON PIN.... ON OLD MERCS THE ROD SETST IT STRAIGHT..... NEWER 2.5 .... THE PISTION KEEEPS IT WITHIN RIGHTS....MY SAY.... IF SLOPY BORE WILL EAT ROD BEARINGS.... NEED STEEL CAGEES.. NUF SAID.....
12-05-2018, 09:16 PM #23Supporting Vendor
- 11,838
- 163
- 11
- 795
Thanks for the help with the parts Dave S...
Happy Holidays ,
Jay @ JSRE
Jay @ JSRE
12-06-2018, 11:04 PM #24Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1977
Thank YOU ... Jay S......Merry Christmas.... To all.
12-06-2018, 11:17 PM #25
12-06-2018, 11:23 PM #26Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1977
Queens NY.....Remmber... Broad channel races?......Best of the brungem what yaa got funnnn....
12-06-2018, 11:28 PM #27
12-07-2018, 12:14 AM #28Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1977
Starat.... RAT city....Dammm went thru that every day on the way to redhook bk....Worked on the 150 st bridge new overpass....JFK.... sucky days.... now in sunny Va.....But the Broad beach was the thing in the old days....
12-07-2018, 12:19 AM #29Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1977
Did we say Deck Hight????HeeHee... Just cut the tops Sharper port pulse with rings higher...
12-07-2018, 01:44 PM #30Supporting Vendor
- 11,838
- 163
- 11
- 795
Got the part Dave , looked new !!!
Thanks ,
JayJay @ JSRE
Merc 2.5L tall deck 150 Block
By Go Time in forum Parts WantedReplies: 1Last Post: 12-18-2017, 12:22 PM -
Block Deck surfaces
By bullet19 in forum Technical DiscussionReplies: 4Last Post: 02-22-2005, 08:06 PM -
wtf does closed/open deck omc block mean???
By baja200merk in forum Technical DiscussionReplies: 3Last Post: 09-15-2003, 02:12 PM -
Question...Engine hight & nose cone
By Barefoot Bob in forum Props, Setup, and RiggingReplies: 11Last Post: 11-24-2002, 09:54 AM -
Need tall deck 454 or 502 block
By D rocket in forum General Boating DiscussionReplies: 2Last Post: 09-30-2002, 07:51 PM
