Results 1 to 11 of 11
    Johnson City TN
    2006 Mercury 250xs
    2006 Mercury Racing 250 XS
    Motor is in great shape, freshwater only, and has 0 hours on fresh rebuild. ECU hours are 665 at time of rebuild. Motor was professionally rebuilt, injectors cleaned (2 replaced with new), and has only been started and ran on test stand to verify proper operation. Fuel rails were disassembled and cleaned, and all regulators and tracker valve were inspected. Compressor was inspected and fuel/air pressures are spot on. 20” shaft, Torquemaster Lower Unit 1.75:1, Fat Shaft. New water pump, gear lube and lower unit has been pressure tested.
    Cowling and decals are in great shape, trim and tilt works smooth and strong. This motor has a higher rev limit than a Pro XS and runs on 87 octane regular gas.
    Motor is ready to bolt on and go, was built for a project boat but not used.
    $7500 can ship if buyer makes freight arrangements
    BryanClick image for larger version.
ID:	424234Click image for larger version.
ID:	424238Click image for larger version.
ID:	424239Click image for larger version.
ID:	424240Click image for larger version.
    423 254 0 three 7 one
    text or call
ID:	430159   Click image for larger version.
ID:	430160   Click image for larger version.
    Nov 2018
    Flat Lick
    Where are you located?
    Florence, SC
    Can you share what the Rev Limit is...?
    May 2007
    STL
    If stock a 2006 should be 6250 and DBR can take to 6800
    [IMG][/IMG]
    Johnson City TN
    Sorry for the delay in responding
    The engine has 6250 rev limit and is located in Elizabethton (near Bristol) Tennessee
    thanks
    Johnson City TN
    STILL FOR SALE!
    Thanks
    Jul 2011
    Lake Lanier, GA
    I’m interested. PM me to discuss?
    Johnson City TN
    PM sent
    Thanks!
    Johnson City TN
    Lower price....TTP
    Feb 2019
    Malta
    Location please?
    do you ship to Malta?
    Johnson City TN
    Motor is sold
    thanks
  1. 2006 Mercury Optimax 250XS Sportsmaster Lower
    By bigolbass in forum Outboard Engines
    Last Post: 07-14-2018, 11:22 AM
  2. Twin 2006 Mercury 250XS 25" offshore mids 755hrs
    By Mito Lete in forum Outboard Engines
    Last Post: 06-09-2018, 08:41 AM
  3. Replies: 1
    Last Post: 06-07-2016, 11:34 PM
  4. 2006 Mercury 250XS
    By dirtbagger in forum Outboard Engines
    Last Post: 08-31-2015, 06:00 PM
