Results 1 to 11 of 11
Thread: Need prop help
    Jan 2018
    Need prop help
    Hey all, i need help from the prop gods. I have a 2020 actioncraft flats boat with a 225 efi on a bobs 6 jackplate. I have a mirage plus 19p 3 blade, pushes the boat 56mph @5700rpm but thats with the jack plate burried and the motor against the transom, i can get 59.5mph if i leave the jack plate down and trim up the motor just a little but im above 6k rpms.
    I tried a regular 21p yamaha prop from a friend. And had the same results. Prop had very little cupping. Prop blows out very easy
    I got my hands on a Mark Croxton Razor3 23p, that prop allowed me to run with the jack plate all the way up and give the motor some trim which i need when im running the flats. BUT!!!, i lost 10mph and 4900rpms is all i can get from the motor. This prop does shoot a beautiful rooster tail tho haha
    Jan 2018
    Alabama
    I would suggest a 20" or 22" pitch Trophy - one of my favorite "general purpose" props. They deliver great holeshots (good for getting up quick in shallow water), they really hold the bow at elevated heights (needs less trim angle), and they convert rotation to forward speed very effectively. I've run them on Johnsons, Mercurys, and both performed within a few mph of their 3 blade competitors. Fast and durable - Gordon
    Jan 2018
    thanks, ill give one a try, what about switching to a 4blade
    Jan 2018
    Alabama
    The Trophy is a 4 blade.
ID:	424159Click image for larger version.
ID:	424158Click image for larger version.
ID:	424160Click image for larger version.
    Sep 2017
    Ashland city tn
    Is the croxten prop a over the hub prop or thru hub? Do u have low water pickup and what is ur propshaft to pad where u normally like to run it?
    Jan 2018
    It has a tourq flo hub if thats what your asking. Prop is also 3/4 inch smaller in diameter then my mirage plus. I havent been able to find a sweet spot on engine height because i cant raise it with the 19. I can bring the jack plate all the way up and trim the motor some and still struggle to get above 5000rpms with the croxten. No low water but i maintain waterpreassuer with the jackplate all the way up with some trim. I feel like i shouldnt have a problem spinning this prop but forsometreason it does
    Sep 2017
    Ashland city tn
    Overhub or thru means - exhaust travel thru center of prop or does it travel around the center of prop. Over hub will have a small diameter center hub vs thru hub will have a large center with a barrel shape
    Sep 2017
    Ashland city tn
    Chopper prop is over hub
    Jan 2018
    The dull looking prop is the mirage plus 19p the polished one is the croxten
    Attached Thumbnails Attached Thumbnails 8F9581F7-90A5-42D2-B692-266585827F14.jpg
    Jan 2018
    Alabama
    Both of these are through-hubs as in the exhaust going through their hubs. How much does your boat weigh?
    Last edited by Gordon02; 12-02-2018 at 09:42 AM. Reason: I miss-read the descriptions.
    Jan 2018
    Dry weight says 1,305lbs. But add motor 4 batteries trolling motor fuel. Id say 2000-2200 ....
  1. F1 / F2 Racing Items for Sale!! Dewald props, Performance Prop, Prop test wheel...
    By Spectre Powerboats in forum Misc. Parts and Accessories
    Last Post: 02-20-2018, 03:01 PM
  2. Replies: 1
    Last Post: 02-03-2018, 02:08 PM
  3. OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
    By Tunnelvision1995 in forum Technical Discussion
    Last Post: 09-12-2017, 08:03 PM
