Results 1 to 6 of 6
    Sep 2018
    oh
    Small holes in bottom
    Getting ready to lay in the 1708 and balsa, and noticed some small holes in the bottom (some I made and some were small punctures). So I cleaned them up with small dremel.
    To prevent resin and mat from dropping through the holes, I thought I would apply tape on the bottom(to save grinding when I flip it over)
    Good idea?
    What kind of tape?
  2. Likes NICE PAIR liked this post
    7 Post(s)
    Perfect.
    Masking tape. Resin won’t stick to it.
    Mix up some resin/cabosil and microfiber (1/8” glass fiber) and fill the holes when done.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  4. Likes NICE PAIR, W2F a V-King liked this post
  5. #3
    Sep 2018
    oh
    Great. Thanks. Some instructions say to wet surface with resin before laying in the mat. Does mean resin with or without hardener?
    Mar 2009
    Port Saint Lucie
    Pre wet the dry boat with mixed resin before you put down the glass.
  7. Likes NICE PAIR liked this post
    Feb 2005
    seattle
    i've had goos luck with clear packing tape. i only use epoxy on hull with fully cured resin. vynalester [sp] resin may also work, but i just prefer the epoxy. i would use tec-mix to plug the holes up from the bottom. the t-m has very good abrasion resistance.
    Sep 2002
    Solvang, Calif
    I poked a couple of holes thru the bottom of my boat, DUH. Didn't want to just cover them up on the inside and have them pop off inside the boat one day while running down the lake at 95mph. So... on the outside I beveled the hole. Then put a layer of tape tight outside the hole but loose over the hole. Poked a pin thru the tape to let trapped air out. Then pushed the spooge thru the hole making a bump on the outside. In my mind it looked like an hour glass.
    Gary
  10. Likes NICE PAIR liked this post
  1. best way to fill holes throught bottom of boat
    By lbhsbz in forum Fiberglass and Composites Discussion
    Last Post: 06-05-2018, 05:27 PM
  2. What the best filler for small holes on gelcoat
    By bravo 1 in forum Appearance Mods
    Last Post: 07-16-2011, 09:23 PM
  3. Small holes in lower unit
    By hemi2005 in forum Technical Discussion
    Last Post: 04-01-2010, 02:45 PM
  4. Difference in 2.4 head gaskets? (big holes vs small holes)
    By WATERWINGS in forum Technical Discussion
    Last Post: 10-18-2006, 08:59 AM
