Results 1 to 15 of 27
11-20-2018, 07:03 PM #1
Favorite tool for removing core,and why
For those that have,or are doing core work.Whats your favorite tool and why? What works the best on reasonably good core.The rotten would be fairly easy by most methods, but the good stuff,not so much.
11-20-2018, 07:44 PM #2
I like to use a sawzall to get under the loose skin. Unless the core is really good you can usually get up to the edge with the saw then peel the skin off. A circular saw with the depth set carefully is next to dice the core into sections or strips. Follow up with an “oscillating tool” to pop up the sections. Make the sections as small as you needto to make them easy to get up. Pry bars, chisels, scrapers and hammers are also helpful!
Josh Peterson
11-20-2018, 08:25 PM #3Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
My tool of choice is the lancelot. But it ain't for the timid. https://www.amazon.com/King-Arthurs-.../dp/B0000224SJ
LakeFever liked this post
11-20-2018, 09:34 PM #4
tux974 liked this post
11-21-2018, 01:49 AM #55000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
+1 on the Lancelot. It made short work of transom removal as well. But the minute that you aren’t scared of it, put it down. You are about to get hurt.
I also used this:
https://m.harborfreight.com/4-1-2-ha...eel-66613.html.
It never showed any signs of wearing out either.
NICE PAIR, sharpeye Mike liked this post
11-21-2018, 03:49 AM #6
I’ve been wondering about that harbor freight wheel. I guess I’ll pick one up next time I’m in town...
Josh Peterson
11-21-2018, 07:32 AM #7Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
Harbor freight? That is chinese junk and def could hurt ya. I don't buy anything from them. Purveyors of junk products.
NICE PAIR thanked for this post
11-21-2018, 07:52 AM #8
Air chisel but know how to use it and a 4" grinder.
11-21-2018, 09:46 AM #9
best tool ever for this imo...
The picture of the blade is not the exact one I used, but it is a decent picture of what came with my kit from Dewalt, and I bought more of these as you will go through a few. It lays almost flat against the hull and cuts flat through the tough good core areas.
And then to grind away larger areas of uneven glass, core or what ever...This grinding wheel below (what NicePair suggested) is worth it's weight in gold...imo....
I had Zero breaches in my hull and I removed Everything in the hull except the hull shell itself.
Here is a link to what came in my Dewalt kit, there are a couple other offset cutting bits to get completely flat if needed. I used those to separate my deck from the hull in the transom well area. If memory serves...I think it was about $130
https://www.dewalt.com/products/powe...ol-kit/dwe315kLast edited by W2F a V-King; 11-21-2018 at 10:05 AM. Reason: Added link
texasvector liked this post
11-21-2018, 09:53 AM #105000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
cooperider liked this post
11-21-2018, 11:05 AM #11Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
[QUOTE=W2F a V-King;3093045]best tool ever for this imo...
And then to grind away larger areas of uneven glass, core or what ever..QUOTE]
Fein is the original designer of these tools and I’ve had one for about 25-30 years. Cost a fortune back then and could only be found in higher end specialty tool stores. Originally bought for doing flooring to cut door jams, etc. Great tool with many uses. My original still performs like new.
Thinking their patent ran out cause now everybody makes them for a lot less money, even Harbor Freight has a cheap knock off of them.
It seems they all have the same blade mounting so all the blades work on all of them. Made getting blades and attachment accessories a lot easier.
W2F a V-King liked this post
11-21-2018, 11:13 AM #12Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
You can re sharpen those blades your self with a small triangular file. They cut better than new.
11-21-2018, 09:14 PM #13
Thanks to all that have responded,I have most of the tools but not all.What I'm lacking is youth,and ambition.Not looking forward to the next chapter!
nitro_rat liked this post
11-22-2018, 05:53 AM #14
11-22-2018, 08:17 AM #15
I use cheap menards grinders. The dust will eat them up over time
Favorite tool you didn't think you would use?
By lokinutz in forum The Scream And Fly LoungeReplies: 24Last Post: 11-13-2011, 05:15 PM -
removing rotted core, how far do I go?
By Tx91z28 in forum Fiberglass and Composites DiscussionReplies: 8Last Post: 07-10-2011, 04:14 PM -
removing old core
By v-king todd in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 01-15-2008, 04:22 PM -
Best tool for removing trim anode on offshore mid
By Markus in forum Technical DiscussionReplies: 2Last Post: 04-16-2007, 11:26 AM -
Removing stuck Pinion Shimming Tool Help!
By rockettman in forum Technical DiscussionReplies: 1Last Post: 01-19-2007, 10:52 AM
