Results 1 to 8 of 8
Thread: Good steering system
11-16-2018, 09:24 PM #15000 RPM
- Dec 2005
- Valrico Fl.
- 564
What steering system will have less play and the closest ratio . The hydraulic steering seems to not be as sensitive as the no feed back sea star . My hyd sea star is ok , it has a small leak developing at the end of the cylinder and I am thinking about maybe switching from hydraulic to a no feed back steering system ,open for any ideas . Boat is a 18 HPX maverick flats , with a Vf115 SHO runs mid fifty’s no jack plate . Thanks for any suggestions
11-17-2018, 07:57 AM #2
cant even fathom the thought of going BACK to cables from hydraulic. Fix the leak and bleed it properly it should work great. If you still want faster lock-to-lock install the next size larger helm. If you now have the 1.7 helm you can step up to the 2.0 or 2.4 if needed.
limited skills
Will hedrick liked this post
11-17-2018, 08:02 AM #3
I don’t do the NFB. True dual cables with dual racks is the only way to go for cable steering. These helms are no longer manufactured. It won’t ever be as smooth as hydraulic.
Josh Peterson
11-17-2018, 02:40 PM #45000 RPM
- Dec 2005
- Valrico Fl.
- 564
11-18-2018, 10:46 AM #5
do you know what helm you have now?
assuming your 4 turns is with a 1.7 helm then:
2.0 helm = 15% less turns or 3.4 lock to lock
2.4 helm = 29% less turns or 2.83 lock to lock
These are just my calculations but I'd guess Seastar has this info available somewhere. I would check with them or a shop that has done more installations than the few I've donelimited skills
11-18-2018, 11:14 AM #6
Bleeding hydraulics is important, as well as wiping down the rods to clean debris off before they damage the seals.
11-18-2018, 12:12 PM #75000 RPM
- Dec 2005
- Valrico Fl.
- 564
Will I found out a couple years ago what a giant difference it made when I bleed the system that’s good info . loop I will try and find a number on my helm than hunt some more and try and get more info on the helms ratio . Thanks
11-18-2018, 12:20 PM #8
Higher capacity helm reduces turns lock to lock but increases wheel effort. This can be remedied with a larger diameter wheel if desired.
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
Will hedrick, loop liked this post
Steering system help opinion on system
By camaroguy71 in forum Props, Setup, and RiggingReplies: 5Last Post: 04-01-2016, 08:33 AM -
whats a good steering system??
By Bigjohnsons in forum Props, Setup, and RiggingReplies: 1Last Post: 02-01-2007, 07:55 PM
