Page 6 of 39 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 ... LastLast
Results 76 to 90 of 581
  1. #76
    Jul 2017
    Dothan, AL
    Mixing some 1/4 chop strand in with the thickened resin should have kept it from cracking. I used thickened vinyl ester on mine with 1/4 chop, and didn’t crack. I filled my gaps all in one batch the same as you did as well.
  2. Thanks tnelsmn thanked for this post
  3. #77
    Sep 2016
    McHenry,Illinois
    I mix milled fibers in my resin first then finish thickening with cabosil. Never had any cracking...but resin thickened with only cabosil will crack in larger voids as it is brittle without either chopped strands or milled fibers.
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork (Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Ranger 17' Aztec / Merc 115
    Hustler 16' Victor
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel / Johnson GT115 (current project)
    Hustler 16' Victor
  4. Thanks tnelsmn thanked for this post
  5. #78
    Dec 2011
    Ludington michigan,on the shore
    Don't know if this is right,but I set my limit thickness with thickened Cabosil to 1/4" after that milled fibers.Also,the esters I think tend to be more brittle than epoxys.
  6. Thanks tnelsmn thanked for this post
  7. #79
    Got hot and cracked. Can't fill deep areas like that with just putty. Too much exotherm.... Next time fit a small pc of wood and putty that in then glass over. I wouldn't worry about it being cracked. Won't weaken the trans after glass is over it.
  8. Thanks tnelsmn thanked for this post
  9. #80
    Aug 2015
    NE Tennessee
    Quote Originally Posted by DanUmbarger View Post
    Guessing you did mix your resins and hardener before adding the cabosil and milled fibers?
    I used epoxy and made some thick mixture transitions in the same areas you did without cracking. Not sure if that's the reason or not.
  10. #81
    Sep 2016
    McHenry,Illinois
    I've done it both ways...doesn't matter as long as it's mixed well. I've only used epoxy a couple of times on small repairs so I don't know much about it.
    Quote Originally Posted by W2F a V-King View Post
    Hustler 16' Victor
    Hustler 16' Victor
  11. #82
    Jun 2018
    Floating around
    Im unsure about marine epoxy being 100% solid but most quality epoxies are so when they cure there is zero shrink and no cracking as a result. I dont know a thing about the ester stuff
  12. #83
    Minneapolis MN
    In my case I mixed the carbosil first to get it thickened. Took a while to figure out how much to add. If I would've added the hardener first, then tried to figure out the mix ratio of carbosil, I think I would've run out of time to get it all in before it started to kick.
  13. #84
    Minneapolis MN
    I've got the transom mostly glassed into place at this point. I have three layers of 1708 over the sides and bottom tabbing it in. Went about 1-2" then about 3-4" and the last at 6-8" I have one piece of 1708 over the entire transom and plan to do one more overlapping the sides by another 6-8" I'll also extend the bottom edge forward about 4" and will wrap the top edge as well. The top edge will get more layers of glass finishing off the splash well when the deck goes back on.
    Also started laying down a layer of 1708 across the entire bottom wherever the core was. I want to give that outer layer a bit more strength before putting down the core.
    Getting all suited up sure helps cut down on the itch factor.
    Attached Thumbnails Attached Thumbnails IMG_5391.jpg   IMG_5392.jpg   IMG_5393.jpg   IMG_5395.jpg   IMG_5396.jpg
  14. Thanks Fritchit thanked for this post
  15. #85
    Hastings,MN
    are you laying each layer while its still tacky ?
    have you used peel ply when you stop for extended periods ?
    <> God is great , Beer is good , Boaters are crazy <>
  16. #86
    Aug 2015
    NE Tennessee
    Very nice. Will be really strong when done.
    It's amazing to me how thin the hull gets after it turns up from the hard chine on up to the flanges where the deck meets the hull. Or mine was anyway....seems there were many variations on the builds, mine was 1979 and had float boxes, so I removed mine.
    I laid extra layers of 1708 in my transom area too.
  17. Likes tnelsmn liked this post
  18. #87
    Minneapolis MN
    Quote Originally Posted by frogII View Post
    I've been either laying multiple layers at once or letting it cure for 24+ hours and sanding it completely with 36 grit on a DA.
    Haven't tried peel ply yet. I probably should as I get into bigger lay ups.
  19. #88
    Sep 2016
    McHenry,Illinois
    I believe your using polyester resin(that's what I used on mine)...you might want to check into buying the resin with no wax added so you don't have to sand between layers after cured. My distributor sells it both ways...with and without.
    Hustler 16' Victor
    Hustler 16' Victor
  20. Thanks tnelsmn thanked for this post
  21. #89
    Minneapolis MN
    Slow and steady progress, little bit at a time. I'm calling the transom complete at this point. Three layers of 1708 over the edges and two full pieces of 1708 across the entire transom and extending out the sides 10" and 16"
    Laid up the next piece of 1708 across the bottom. Ground everything outside of the floor area down to the woven roving, then scuffed it all with a 36 grit on a DA. I'm doing this step due to the amount of holes and repairs done to the bottom of the hull. Just some extra peace of mind.
    Had the shop I used to work for take a stab at forming up replacement for the factory trim. I'm very happy with the result, I'm going to try and get this to form to the hull. I might have to order in some softer aluminum. They will be able to form this in 12' sections. Once I have it fitted I'll weld and blend all the seams then attach it to the hull. I really want to keep the factory look.
    Attached Thumbnails Attached Thumbnails IMG_5404.jpg   IMG_5405.jpg   IMG_5407.jpg   IMG_5408.jpg   IMG_5409.jpg
  22. #90
    Jul 2017
    Dothan, AL
    Looking good!!! You will be laying core before ya know it. Your work makes me wonder if I short changed on my transom layup though lol!!!!
  1. 1978 vking rebuild
    By rjdubiel in forum Fiberglass and Composites Discussion
    Last Post: 04-30-2021, 01:35 PM
  2. complete rebuild Monster Viking
    By primerate2 in forum Appearance Mods
    Last Post: 10-25-2011, 02:14 PM
  3. Blue 1978 viking lansing, mich
    By 200VEGAS in forum General Boating Discussion
    Last Post: 08-07-2010, 09:04 AM
  4. 1978 Galaxy rebuild
    By Auggie2612 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 08-25-2009, 10:32 PM
