Results 46 to 60 of 581
Thread: 1978 Viking rebuild
12-14-2018, 06:34 AM #46
That's the finish you want,rough and porous and clean. I would recommend a good scrub with acetone just before your first coat.Looking good!
tnelsmn thanked for this post
12-14-2018, 08:04 AM #47
I would go at least 36 grit. 24 and 16 grit are available, I would go 16 grit if I could. You want the most "tooth" so the new resin can "bite" the old as it will be a "mechanical" bond rather than a "chemical" bond.
Josh Peterson
tnelsmn thanked for this postNICE PAIR, DanUmbarger liked this post
12-15-2018, 06:17 PM #48
Im new to boat cores but done a ton of body work/paint. Use to have a body shop years ago. Best tool for stripping down glass smooth without eating through it is one of these imo
We use 5" and 6" dia disks in 26 and 36 grit and when you want to feather you cut 2" long flats around the perimeter so its octa shaped and it softens it right up, makes blending nice. These things are VICIOUSLY fast RPM and loud as hell so if you get one be sure to only use properly rated disks and backers. Whatever you do dont be tempted to put stones or other grinding disks on one of these it will grenade everywhere. I use the speed control to dial up/down after its loaded as Im working it so not to over rev it. They work very well and make fast work of stripping glass and bondo down with tooth, and flat. Dont sit still keep it moving and blendingHydrostream dreamin
12-17-2018, 04:52 PM #49
Used the Cutz-all wheel and removed what was left of the old core. Just have to remove and clean up what's left of the old repairs and the bottom is ready to start going back together. Then onto removing the transom and outer stringers. Slow and steady progress.
NICE PAIR, texasvector liked this post
12-17-2018, 05:04 PM #50
Looking good!
Have you been tracking your hours on this by any chance?Hydrostream dreamin
12-17-2018, 05:38 PM #51
NICE PAIR liked this post
12-17-2018, 05:52 PM #52
I'd love to know the hour breakdown at two points;
1 once your stripped and prepped
2. When your done the rebuild
Would be a big help when i plan a sched out for mine. I gotta yell ya this and the other resto thread of that drag hull are super fun to follow along. The only thing Im wondering is why I didnt join S&F earlier, this place is awesome
12-17-2018, 08:22 PM #53
Sure, I'll add hours and money spent along the way at milestones. I've been on the site for a decade, since we started this project, just didn't post much back then. Never thought I'd be posting a build of my own. I'll try and hep any way I can.
As of now the only totals I know are for the cradle. Approximately 27 hours and $300.
LakeFever thanked for this postLMT383, Hippie459MN liked this post
12-27-2018, 12:25 PM #54
Finally made some more progress last night. Work schedule and the holidays kept me away from the boat for almost 10 days.
Both upper stringers are cut out and the port side is completely cleared out and ready for new. Removed the factory repair on the port side near the front of the floor, below a few layers of glass was almost 1/2" of just resin. Ground all that out until I could see the color of the gel coat coming through.
Also started removing some the previous glass work laid years ago. The stuff popped right off the top layer of factory glass. It appears they never ground/prepped the factory finish before laying new glass. This just re affirms what I've read many times. This is a mechanical bond, not chemical. The surface needs to be prepped. There's also a lot of excess resin from when they were putting in the transom that ran down the transom across the back of the core and settled into the pad area. This has been aggravating to remove. Still working at that.
Here's a few more shots.Last edited by tnelsmn; 12-27-2018 at 12:30 PM.
W2F a V-King, NICE PAIR liked this post
12-27-2018, 01:25 PM #55
Nice work! And it IS a lot of work for sure.
But will be worth it when done!James H. W2F a V-King... Want 2 Fly a V-King
01-02-2019, 02:16 PM #56
Made a bit more progress over the holiday weekend. I've removed all glass that was added years ago. That was pretty easy for the most part since the hull never got scuffed, it just popped right off with a putty knife.
Removed the transom that was replaced ten years ago, it was soaking wet when it came out.
Removed almost all excess resin that drained into the pad area from when the transom was installed.
Just a bit more prep feathering out the holes in the bottom and taping them off from the outside. New glass should be going down in repair areas within a week.
Here's some more pictures.
01-02-2019, 02:18 PM #57
Nice work, it will be worth it in the end!
Josh Peterson
tnelsmn liked this post
01-02-2019, 02:31 PM #58
01-10-2019, 02:53 PM #59
Slow and steady progress. Passed a hurdle for myself by laying down the first layer of glass into repair spots. First time in my life doing fiberglass work. Wasn't as bad as I was expecting. These are just the first of a few layers of csm I'm planning to lay in the repair areas. My thoughts are to do 4-5 layers of csm overlapping each layer with the next being an inch or so larger all on sides.
Is it ok to lay up multiple pieces of csm over each other and just waiting for one cure time? I watched a guy on youtube lay up four layers of glass at one shot. Or should I continue with my plan to DA sand with 36g between each layer after allowing 24hrs of cure time? I figure for my novice self this would get me into less trouble.
Hours so far, 30 into disassembly and prepping for glass work. Keep in mind I didn't start with a complete boat. Floor, center stringers, and most the core was already out. I did have to remove some previous repairs.Last edited by tnelsmn; 01-10-2019 at 03:29 PM.
01-10-2019, 03:17 PM #60Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Either way will be fine. I do a 1st piece and let it harden then build up with several layers. Avoid any air pockets and sand smooth after it hardens.
1978 vking rebuild
By rjdubiel in forum Fiberglass and Composites DiscussionReplies: 155Last Post: 04-30-2021, 01:35 PM -
complete rebuild Monster Viking
By primerate2 in forum Appearance ModsReplies: 10Last Post: 10-25-2011, 02:14 PM -
Blue 1978 viking lansing, mich
By 200VEGAS in forum General Boating DiscussionReplies: 1Last Post: 08-07-2010, 09:04 AM -
1978 Galaxy rebuild
By Auggie2612 in forum Jet Boats, V-Drives and Stern DrivesReplies: 12Last Post: 08-25-2009, 10:32 PM
