Page 22 of 39 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 LastLast
Results 316 to 330 of 581
  1. #316
    Jun 2018
    Floating around
    Awesome! How long do you think the wet sanding and polishing will take?
  2. #317
    Minneapolis MN
    I think it can be wrapped up in the next week or two. Thats what I hope at least.
  3. Likes LakeFever liked this post
  4. #318
    Minneapolis MN
    The finish sanding is pretty much finished other than a few touch ups here and there that I'm finding as the buffing is happening. After some guidance from an experienced body man, I started dry sanding the gel. That worked really well and went much faster using a DA. I started with 220 then 400, and had to switch to wet sanding with 800.
    Started buffing it out and I still can't believe how cool this stuff is. Metal flake is so sweet! Still a ways to go with buffing. But so far it's looking good.
    Attached Thumbnails Attached Thumbnails IMG_6764.jpg   IMG_6765.jpg   IMG_6768.jpg   IMG_6767.jpg   IMG_6769.jpg
  5. #319
    May 2020
    Looks pretty damn sweet to me!
  6. Thanks tnelsmn thanked for this post
  7. #320
    May 2020
    Did you glass the underside of your plywood floor before setting in on your stringers? I assume you did and was wondering what to use for cloth thickness...1708?
  8. #321
    Minneapolis MN
    Quote Originally Posted by Jmr1974 View Post
    I did a layer of 1.5oz CSM on the bottom of the of the floor.
  9. #322
    May 2020
    Quote Originally Posted by tnelsmn View Post
    Thanks, I’m guessing you did it mainly for moisture protection not for rigidity...
  10. #323
    Minneapolis MN
    My only intent was sealing the wood. Any rigidity is a by product of that for me.
  11. #324
    May 2020
    I also noticed in one of your pages a while back you painted the pad area before putting your floor plywood down, I guessing you did it where you anticipated any water could sit when your out boating. Did you use gel or paint? How did you apply it and what grit sanding did you use to accept the gel or paint to the glass?
  12. #325
    Minneapolis MN
    Everything below the floor was gel coated. Applied with a brush. Well, mostly dumped in and spread out with a brush. I sanded everything with 36 before applying gel. Mostly because 36 works so well to knock the sheen of cured resin and prep it for the next layers. Theres a video of this process on my youtube channel.
  13. #326
    May 2020
    I’ll have to check out your video
  14. #327
    Minneapolis MN
    Well, I can say that the fiberglass and gel work is finished on the build!
    I ended up starting over sanding the gel on the deck. I found a lot of sanding scratches and a few spots I wasn't happy with so I started over with 240 on a hand block. I just made a few passes and quickly moved up to 400 and so on. Followed that with a three stage buff using 3M Perfect-it gelcoat.
    I pulled it out of the garage for the first time in almost two years. It was great to see it in the sunlight agin! I had to set the windshield on it for a few pictures. I'll straighten out the frame before it gets mounted for good.
    The interior needs a good cleaning and the rigging can begin. It's going to be hard to start drilling holes in it.
    Sitting a 875 total hours.
    Attached Thumbnails Attached Thumbnails IMG_6817.jpg   IMG_6818.jpg   IMG_6830.jpg   IMG_6833.jpg   IMG_6834.jpg
  15. Thanks LakeFever thanked for this post
  16. #328
    Jul 2019
    Tennessee
    What a beautiful job!!! you are now a pro! You should be very proud of that job!
  17. Thanks tnelsmn thanked for this post
    Likes LMT383 liked this post
  18. #329
    Jun 2018
    Floating around
    Looks so good, really so soo good you did a great job laying this thing up and an even better job with entertaining us all in this thread with pics and vids. I learned a ton and bought my next project mostly because of this thread which i will be referencing a ton when i get to mine. Congrats on level 11
    Can hardly wait to see some vids of it flying
  19. Thanks tnelsmn thanked for this post
  20. #330
    May 2020
    Wow that thing looks great, hell of a job! The finish line is near for you.
  21. Thanks tnelsmn thanked for this post
  1. 1978 vking rebuild
    By rjdubiel in forum Fiberglass and Composites Discussion
    Last Post: 04-30-2021, 01:35 PM
  2. complete rebuild Monster Viking
    By primerate2 in forum Appearance Mods
    Last Post: 10-25-2011, 02:14 PM
  3. Blue 1978 viking lansing, mich
    By 200VEGAS in forum General Boating Discussion
    Last Post: 08-07-2010, 09:04 AM
  4. 1978 Galaxy rebuild
    By Auggie2612 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 08-25-2009, 10:32 PM
