Page 23 of 39 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 LastLast
Results 331 to 345 of 581
  1. #331
    Minneapolis MN
    Thanks a lot guys! I'm far from a pro but I could sure save time and do a better job on the next one.
    The first parts have officially been bolted on for good. Just the original emblems, but gotta start somewhere.
  2. Likes mrichartz liked this post
  3. #332
    Jun 2018
    Floating around
    I bet it was very difficult to drill that first hole but your right you just gotta start somewhere. Do you have a cross line laser? I’ve been using mine for tons of layout work. Thinking if you used one for laying out the engine mount holes you could get it 100% on center and square to the pad
  4. Likes tnelsmn liked this post
  5. #333
    Jul 2005
    AZ
    Quote Originally Posted by tnelsmn View Post
    It's the little things the make the boat ok or awesome.
    There's no just anything..lol.
    Definitely time well spent part of the learning curve(saving time next time). And not like you learned doing a half as job..Done enough of them to know there's always a learning curve somewhere.
    Obviously not going to slack off now so awesome it will be. Can't wait to see it floating
    '84 Checkmate Convincor
  6. Likes tnelsmn liked this post
  7. #334
    Minneapolis MN
    Bare hull weighed in at 745lbs.
  8. Likes LakeFever liked this post
  9. #335
    Sep 2017
    Ashland city tn
    Sweet. she gonna b fast
  10. Likes tnelsmn liked this post
  11. #336
    Minneapolis MN
    Took a little bit of a break from working on the hull and took apart the engine. Haven't disassembled the power head, it looked good inside when I pulled a head out of curiosity.
    Everything else is apart and been degreased/cleaned.
    Whats planned now is doing a cone on the lower unit, new seals, fluid, and a water pump.
    Adding solid mounts, switching everything over to a newer 3 ram trim with the big tiller, and painting the mid.
    Rebuild the carbs, fuel pump, and replace all fuel/bleed lines.
    Cross fingers and hope it runs...
    Attached Thumbnails Attached Thumbnails IMG_5051.jpg   IMG_5285.jpg   IMG_6876.jpg   61817466267__C757A27C-7F22-4D8F-81FB-BC17B5EE70AC.jpg   IMG_6877.jpg
  12. Likes mrichartz liked this post
  13. #337
    Jul 2005
    AZ
    How's that harbour freight stand work
    Iffy or?
  14. #338
    Minneapolis MN
    Iffy or?
    Ehhh it does the job. It's been holding the thing for two years. But it's not very stable. I always kept a strap around the mid so it wouldn't turn. It would want to turn one way or another then the whole thing would tip that way cause the pin to rotate the stand was so sloppy. It never fell but I always worried about it. Going forward it will be assembled on the transom.
  15. #339
    Sep 2017
    Ashland city tn
    I got one them to and pin they use for the top to rotate it just plum sucks , pin small hole huge
  16. Likes tnelsmn liked this post
  17. #340
    Mar 2004
    Brooklyn Park, MN
    bolt 3 pieces of plywood right to the plate and drill the top motor mount holes (instead of using the included mounts of the stand) and weld the pin and they work just fine. My opinion. Let me know where you find carb floats if you need to replace yours. I have the same exact motor and I think I need floats for it. Have not looked for them but I heard they are hard to find. AND, outasite here on S&F loves that two ram clamp. Put a bigger tiller arm in it and he said it is faster than a single ram or 3 ram and lighter. He has one on his orange Vking
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  18. Likes tnelsmn liked this post
  19. #341
    Minneapolis MN
    RJ, a few welds on this engine stand would be a huge help, but I don't own it so I had to make do.
    Just picked up a carb seal kit and a bunch of other parts at Supreme Marine and they said the same about the floats. I think I'm going to try and run it before I tear it all apart.
    I've been hesitant about the two ram trim mainly because the clamp is older so it doesn't have the BIA bolt pattern. I know I can just re drill the jack plate, still thinking about it. Also, I built my fuel tank so big I don't have much room for the remote pump, I checked last night and it won't fit between the transom knees, might be able to get it on the outside edge of the port stringer. I didn't know I could swap out the tiller arm on the older mid. That 2 ram is considerably lighter than the 3 ram just by moving the two around.
    I just figured it would be a lot easier for rigging going with the 3 ram. Now I have more stuff to think about...
  20. #342
    Mar 2004
    Brooklyn Park, MN
    I am running a 3 ram as well. Saves room and I didnt want to pull my 1978 merc apart. I am going to roll my 1978 out of the garage soon to fire it up, has not ran since 2008!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  21. Likes tnelsmn liked this post
  22. #343
    In the boat pumps and hoses over the trans for trim are a PIA.
  23. Likes tnelsmn liked this post
  24. #344
    Mar 2004
    Brooklyn Park, MN
    Remember, these old 1978 motors stock had the through hull lines running through the bottom motor mount transom bolts. Have to make a hose from there to the jack plate but that wouldn't be that bad. Or it would be hell! one of the two.....
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  25. Likes tnelsmn liked this post
  26. #345
    Oh, I know of the holey bolts for trim supply. Still a pump in the boat, and hoses to buy. I went 3 ram and never looked back. Don't miss old style at all.
  27. Likes rjdubiel, tnelsmn liked this post
  1. 1978 vking rebuild
    By rjdubiel in forum Fiberglass and Composites Discussion
    Last Post: 04-30-2021, 01:35 PM
  2. complete rebuild Monster Viking
    By primerate2 in forum Appearance Mods
    Last Post: 10-25-2011, 02:14 PM
  3. Blue 1978 viking lansing, mich
    By 200VEGAS in forum General Boating Discussion
    Last Post: 08-07-2010, 09:04 AM
  4. 1978 Galaxy rebuild
    By Auggie2612 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 08-25-2009, 10:32 PM
