Results 1 to 2 of 2
Thread: 30p Mazco RE4 4 blade
11-10-2018, 10:14 AM #1
This is a clean Mazco RE4 30p the small shaft hub has been pressed out and I have an insert that can be welded into convert it to fat shaft. If you have a small shaft you can just press a hub back in it and go.
$450+ the ride
weldable fat shaft insert is available for $100
pics are on the way
11-12-2018, 11:49 AM #2
14.5x30 Mazco Cleaver 3-Blade
By HydroStreamAE202 in forum PropellersReplies: 3Last Post: 09-08-2015, 09:21 PM -
22 chopper, 26 trophy 4 blade, 30 mazco re3, 17 mirage
By superboattwin250 in forum PropellersReplies: 2Last Post: 05-22-2014, 09:06 AM -
Mazco 25" Hp-4 Vs Mirage Plus 25" 3 Blade
By sonicbob007 in forum Technical DiscussionReplies: 1Last Post: 01-20-2008, 09:12 PM
