Results 1 to 5 of 5
Thread: My Ring 21
    Jul 2007
    Bermuda
    Talking My Ring 21
    Hey everyone, so this is my first performance style boat and first time poking with outboards like this to get maximum speed and handling.
    Bear with me as I have alot to learn. I thought I would share my journey here and hopefully gain some wisdom from everyone.
    Bought a Ring 21 that had a 150hp mariner 2.0L bolted to an offshore mid section.
  2. Likes NICE PAIR liked this post
    Jul 2007
    Bermuda
    Ran nice but I'm a speed junkie, and the motor was a bit less than what I hoped for. so I went and picked up something special. A nice 2.4L Merc,, that also came with a 2.5 that was blown for later fun.
ID:	422612Click image for larger version.
    Jul 2007
    Bermuda
    Begin of dismantling
    Needed a better transom plate to disperse loaded edges from the jackplate, plus bolt hole was leaking slightly. Figured let's swap powerhead, put a new plate on, reseal it all, and see how it runs.Click image for larger version.
    everything is off now, got some cleaning up of the transom to do, will repaint then install new aluminium transom plate and jackplate.
    Oh and while I'm at it, Dry stacking maybe?
    Jul 2007
    Bermuda
    So I went to work and decided to beadblast and run tubes.Click image for larger version.
ID:	422894Click image for larger version.
    Need to weld the support but couldn't be bothered today.
    Nov 2018
    Austin, TX
    Where are you at with the repair work, Baxter? Did you weld the support?
    People strongly suggest Skinny Views because it's awesome.
  1. 7 ring 2.4 in place of 8 ring 2.5 crank
    By headup in forum Technical Discussion
    Last Post: 02-10-2008, 03:53 PM
  2. Mercury Thin Ring vs Thick ring
    By blurred vision in forum Technical Discussion
    Last Post: 07-27-2003, 11:21 PM
