Results 1 to 3 of 3
Thread: 1985 Evinrude 3.6 V8
11-05-2018, 01:43 PM #1Member
- May 2014
- Denver, Colorado
- 49
Hello, I have a 1985 Evinrude ELTCO 3.6 V8. The boat has either Baker or Al Stoker offset heads with blue inserts. Motor has new CDI power packs and voltage regulator. Engine also had stator replaced recently. Has boysen reeds. Motor is a 20" I believe. It does have a small nose cone installed. I have converted the boat to premixed and have taken the vro off. Compression test results below. All compression tests were done on a cold motor without a battery charger hooked up and @ 5280' above sea level with throttle closed.
#1. 123. #2. 125
#3. 117. #4. 125
#5. 122. #6. 125
#7. 120. #8. 125.
Engine will come with another standard rotation lower that has a freeze crack. Gears seem to be in working order. Engine will come with a beat up 21" prop. This prop does hook up very well on my boat providing only a 6% slip number. Attached are pictures of the engine. Motor is still installed on boat. Located in Denver Colorado. Would like local pick up but can arrange shipping at buyers expense. I am looking to upgrade to a Mercury 2.5 260 or 280hp or 250xs, 300xs. Looking for a 20" mid with sporty lower unit, would also look at trading with cash on top for one. I dont see many 3.6s around so not quiet sure what they go for so price is currently $4750.
If you have question feel free to call or text. 720-939-6992Last edited by summitrider1; 11-13-2018 at 10:23 AM. Reason: Bad grammer
11-13-2018, 10:21 AM #2Member
- May 2014
- Denver, Colorado
- 49
Price drop. $4,250 OBO.
04-05-2021, 12:17 AM #3
V8 OMC Outboard
summitrider1;3089426]Hello, I have a 1985 Evinrude ELTCO 3.6 V8. The boat has either Baker or Al Stoker offset heads with blue inserts. Motor has new CDI power packs and voltage regulator. Engine also had stator replaced recently. Has boysen reeds. Motor is a 20" I believe. It does have a small nose cone installed. I have converted the boat to premixed and have taken the vro off. Compression test results below. All compression tests were done on a cold motor without a battery charger hooked up and @ 5280' above sea level with throttle closed.
is the v8 still available? Is the B-8 still available?
#1. 123. #2. 125
#3. 117. #4. 125
#5. 122. #6. 125
#7. 120. #8. 125.
If you have question feel free to call or text. 720-939-6992[/QUOTE]1987 Switzer GL-21 OMC V8 Prototype/ Replaced by another V8
1983 Switzer SS-20-C/Evinrude V6
1983 Switzer SS-20-B under renovation
1972 Switzer "Flatback Transom" Super Sport (in storage to be rebuilt at another time)
Replica 1964 Switzer Playboy 1968 125hp Merc Short Shaft
1977 Switzer Super Sport**sold** Reaquired on Sept.29,2016
Join us at The Switzer Regatta & Hot Boat Rally
https://www.facebook.com/switzer.craft.7
OMC Tech: 1985 Evinrude 60hp
By Callum5009 in forum Technical DiscussionReplies: 0Last Post: 09-19-2018, 02:33 PM -
1985 Evinrude 3.6XP 300 V8
By lbhsbz in forum Outboard EnginesReplies: 10Last Post: 12-18-2015, 10:05 PM -
1985 235 evinrude for sale
By xcheesehd in forum Outboard EnginesReplies: 1Last Post: 05-31-2015, 09:04 PM -
1985 Evinrude 150 V6 2 stroke......
By Jeckel707 in forum Technical DiscussionReplies: 16Last Post: 04-25-2008, 08:09 AM
