Page 4 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 46 to 60 of 202
  1. #46
    Sep 2016
    McHenry,Illinois
    It's interesting you didn't put at a keel down the center....will the floor be stiff enough for the seat/s?
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork (Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Ranger 17' Aztec / Merc 115
    Hustler 16' Victor
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel / Johnson GT115 (current project)
    Hustler 16' Victor
  2. #47
    Jun 2001
    There was no keel originally. There was a seat box across the boat where 5he seat mounted. Plan to do that again
  3. Likes DanUmbarger liked this post
  4. #48
    Jun 2001
    Next time you see this it will be upside down.. Bottom time.....
  5. #49
    Jun 2001
    FLip Side............
    Attached Thumbnails Attached Thumbnails IMG_1496.jpg   IMG_1497.jpg   IMG_1499.jpg   IMG_1500.jpg
  6. #50
    Sep 2016
    McHenry,Illinois
    Is that some sort of graphite coating brushed on the hull? Damage from screws too close to the skin? Foam under the floor or just in front of the bulkhead? Looking good Tom
    Hustler 16' Victor
    Hustler 16' Victor
  7. #51
    Jun 2001
    Screws through from the inside many years ago. Foam ONLY up front nothing under the floor. Looks like some speed coat was brushed on from a long time ago.
  8. Likes DanUmbarger liked this post
  9. #52
    Jun 2001
    All Holes THROUGH the transom ( ones used for laminating the new transom in place) plugged with dowels and glassed over. Two bottom punctures from inside screws ground out and patched with 3 layers of weave.
    How do you spell fun ?????
  10. #53
    Sep 2016
    McHenry,Illinois
    I know what "fun" your talking about. I have a new issue since I started my latest restore...I tore my shoulder up and need a shoulder replacement. Went past the normal rotator cuff tear fix and straight to replacement. Gonna work thru it for a few years with physical therapy and revisit replacement later
    Hustler 16' Victor
    Hustler 16' Victor
  11. #54
    Jun 2001
    gettin to some initial sanding to remove the dirt,mold and speed coating on the bottom.Finally getting to see what i got to work with.....OBVIOUSLY someone has worked this bottom quite a bit before... not in bad shape. Edges nice a crisp for the most part.....
    Attached Thumbnails Attached Thumbnails IMG_1509.jpg   IMG_1508.jpg   IMG_1507.jpg   IMG_1506.jpg
  12. #55
    Sep 2016
    McHenry,Illinois
    Looks like someone has taken the hook out of it....what do you think was mounted at the outer edges of the floor that caused your puncture cracks?
    Hustler 16' Victor
    Hustler 16' Victor
  13. #56
    Jun 2001
    According to the original owner he was at the factory when thi swas built and it was built with a slight rocker in it, light layup specifically for racing. No clue what the punctures are from.
  14. #57
    CHAIN O LAKES, IL
    15' wildcat tunnel
    Quote Originally Posted by DanUmbarger View Post
    Tom, The only thing that comes thru on my computer is the pic of the patch...is there another pic with the list of races that is not coming thru?
    when will we see the wildcat tunnel, how far along are you?
    ill have to stop in and see it.... is the deck off?
    this is the boat for your v4..... put the 140 suzuki on the victor .
  15. #58
    Jun 2001
    Initialsanding completed. All the previous speedcoat removed....
  16. #59
    Sep 2016
    McHenry,Illinois
    Looks good Tom, all the sanding on the very back edges is why I thought they sanded the hook out....paint or Gelcoat?
    Hustler 16' Victor
    Hustler 16' Victor
  17. #60
    Jun 2001
    I will paint it.
  1. Mercury Tech: A 1972 Tower of Power 1150 basket case project
    By Stevewatr in forum Technical Discussion
    Last Post: 05-31-2021, 04:14 PM
  2. Need Help on Restoration Project
    By NoFloat9 in forum Fiberglass and Composites Discussion
    Last Post: 05-28-2011, 07:56 AM
  3. New winter project 1972 Alisson 16r
    By unclebuck134 in forum General Boating Discussion
    Last Post: 09-07-2010, 01:09 PM
  4. restoration project
    By outboards4life in forum General Boating Discussion
    Last Post: 09-09-2002, 09:48 PM
