Results 136 to 150 of 202
10-05-2019, 01:10 PM #136
10-07-2019, 02:34 PM #137
a few more original artwork repopped decals on the starboard side......
AZMIDLYF liked this post
10-10-2019, 02:34 PM #138Junior Member
- Sep 2015
- wilmington,Il
- 22
I think Jim Smith from Illinois raced this boat.
10-10-2019, 04:22 PM #139
Yes he did. This is his boat...
11-05-2019, 11:24 AM #140
Been working on the string steering geometry and have figured out the right bend for the wing plates as well as the front pulley placements. Had to design and fabricate an oak block to mount the front pulleys to the inside of the angled hull so that they received the cable from the helm on the right angle and fed it out to the rear motor wing plates as well. All is good. Everything is through bolted and stainless steel. Once mock up is done it will be torn back down and the wood blocks sealed with west system and everything sealed and bolted up.
11-10-2019, 01:08 PM #141
steering cable in for the first test fit. A few changes need to be made. Bending the straight wing plates up reduced the angle it can pull for steering a bit. Probably fab a new set of wing plates that are wider to correct that.
Pulley blocks work as designed, plenty of clearance for the cable to bounce around a bit and not hit anything. Probably adjust the drum up on the steering shaft a bit as well.
Deck clearance on the cable is good as well.
That it why you mock it up....
11-10-2019, 04:20 PM #142
Just saw i posted the earlypic of the steering bars with the string through them. Try this pic instead.......
11-11-2019, 05:44 AM #143
It looks like the ends of the wings are a long way above the tilt pivot tube. Is that an optical illusion?
11-11-2019, 06:03 AM #144
11-11-2019, 06:15 AM #145
11-11-2019, 06:20 AM #146Team Member
- Jul 2015
- NC/TN/KY
- 1,056
- 94
- 104
- 1322
- 490
Way cool build! Loving it. Wish I had the talent and experience to restore one. Yours is very intriguing very interesting and cool!! Thanks for sharing!!
11-14-2019, 07:55 AM #147
WOW- Almost 10,000 views. Appreciate the intrest in my boat hobby. THANK YOU ALL !!!!!!!!!!!!
tnelsmn liked this post
11-14-2019, 07:33 PM #1485000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 191
Tavares this March???
11-14-2019, 07:42 PM #149
12-08-2019, 03:03 PM #150
bucket seat mold prep. Hope to lay it up this week. Weather is nice and warm for it..
Mercury Tech: A 1972 Tower of Power 1150 basket case project
By Stevewatr in forum Technical DiscussionReplies: 89Last Post: 05-31-2021, 04:14 PM -
Need Help on Restoration Project
By NoFloat9 in forum Fiberglass and Composites DiscussionReplies: 11Last Post: 05-28-2011, 07:56 AM -
New winter project 1972 Alisson 16r
By unclebuck134 in forum General Boating DiscussionReplies: 0Last Post: 09-07-2010, 01:09 PM -
restoration project
By outboards4life in forum General Boating DiscussionReplies: 5Last Post: 09-09-2002, 09:48 PM
