Results 106 to 120 of 202
07-16-2019, 05:05 PM #106
not hard to do. cut bristles on a brush to make 6 or seven long bristle bunches. dip and splatter. depends on th etype paint or gel you are using and how you mix it. throw them away after every use.
W2F a V-King liked this post
07-18-2019, 05:01 PM #107Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
This is really good looking spatter. Old school indeed. That's how we did it in the 70's. Work of art and not that easy to do the first try.
07-18-2019, 08:10 PM #108
I saw a center console that was done using a sippie cup full of paint and just shaken around. Looked great!
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
07-19-2019, 01:50 PM #109
getting serious now. Deck is installed onth ehull. Through bolted instead of screwed except for the very front. New strip of wood installed so the nut and washer have something to pull tight to the deck. Spent some time on the original rub rail an decided to go with it. Actually buffed up nice with very few dents. Trailer weighed, hull should be onth etrailer tomorrow and then we will get a empty hull weight.
DanUmbarger, tnelsmn liked this post
07-19-2019, 07:26 PM #1105000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
just one seat or two????
07-20-2019, 05:10 AM #111
1954bmw thanked for this post
07-20-2019, 08:13 PM #112The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
looks good thom...
07-20-2019, 08:18 PM #113The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
they also make what they call a "webbing solution" that comes in a gallon can. you shoot it out of a paint gun & it comes out in a squigally pattern. its how they did it on the higher production volume small boats of yesteryear, but is still available.
07-21-2019, 04:35 AM #114Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
The webbing solution we had in the old days was far, far better than the stuff they sell now.
07-21-2019, 01:18 PM #115The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Yes, it was used as a non-skid of sorts, and to give the inside of the hull some color contrast interest. Back in the day before those silly interliners came out...lol
08-01-2019, 01:59 PM #116
Decision regarding the manul jackplate was made. The boat was originally rigged with a homemade jackplate made out of 3" Angle pieces and a wood transom . I will be fabricating the same type of jack plate to maintain this as close to original racing trim as possible. Actual transom wille a 1/4" aluminum plate with two 3/4" pieces of marine playwood laminated to it. Hope to have 1/2" adjustment capability.
Looked at commercially available manual jack plates, but this was never rigged with that type of"tech".. LOL
May end up powder coating the jack plate brackets, haven't decided yet. The rest of the boat will be trimmed out in black .
Pics of the intial lamination...
08-02-2019, 03:45 PM #117
pic of the aluminum plate that the 1 1/2 transom will be bonded to. Plan is to powder coat the plate then bond it the the laminated wood . Not really necessary but want no voids for water between the wood and alum plate.
Alum plate / transom assembly will be thru bolted to the outer set of alum jack plate angles. Should be good for an inline motor.
08-02-2019, 09:57 PM #1185000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
OK, so you are building your own jack plate out of angle aluminum bolted together and the aluminum/wood piece is bolted to those angle brackets and the engine is bolted to that???? Why not just bolt the engine to the angle bracket, jack plate???
08-03-2019, 04:27 AM #119
Not the way it was set up back when it was raced.
08-03-2019, 06:40 AM #1205000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
Is m setup thinking correct?? And where is the mosquito coast, anywhere close to Lauderdale??
Mercury Tech: A 1972 Tower of Power 1150 basket case project
By Stevewatr in forum Technical DiscussionReplies: 89Last Post: 05-31-2021, 04:14 PM -
Need Help on Restoration Project
By NoFloat9 in forum Fiberglass and Composites DiscussionReplies: 11Last Post: 05-28-2011, 07:56 AM -
New winter project 1972 Alisson 16r
By unclebuck134 in forum General Boating DiscussionReplies: 0Last Post: 09-07-2010, 01:09 PM -
restoration project
By outboards4life in forum General Boating DiscussionReplies: 5Last Post: 09-09-2002, 09:48 PM
