Page 6 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 76 to 90 of 202
  1. #76
    Dec 2001
    Yes..... just needs a Rude ................. heehee...............
  2. #77
    Jun 2001
    not even if you gave me one...……..
  3. Likes W2F a V-King liked this post
  4. #78
    Jun 2001
    structural work done on the underside of the deck. time to flip it over and start on the topside......
    Attached Thumbnails Attached Thumbnails IMG_1597.JPG   IMG_1598.JPG   IMG_1599.JPG
  5. Likes W2F a V-King liked this post
  6. #79
    Jun 2001
    deck flipped over. few pics to show what it looks like before....
  7. #80
    Jun 2001
    here are th epics....
    Attached Thumbnails Attached Thumbnails IMG_1600.JPG   IMG_1606.JPG   IMG_1602.JPG   IMG_1604.JPG
  8. Likes W2F a V-King liked this post
  9. #81
    Jun 2001
    this deck has its own set of unique issues. it was built as a race hull and the deck is so think it is scary to grind to reinforce and fill holes. Lots of spider cracks that are ground down as thin as I dare go, then filled with epoxy filler. Also have had a reinforcement layer applied on the underside to these areas for added strength. had to rebuild seveal areas onn the corners of th edeck as well. Deck weighs less than 100 pounds. Two people can run around the back yard with it.....A good multiple coat of epoxy primer and finish coats of Awl Craft 2000 should keep them from re appearing. a few pics of some of the holes that have been filled and almost time for a primer coat to show up all the bubbles and voids I missed..GREAT glassing weather down here, nice and HOT.....
    Attached Thumbnails Attached Thumbnails IMG_1654.JPG   IMG_1652.JPG   IMG_1656.JPG   IMG_1651.JPG
  10. #82
    Jun 2001
    Last major area to address on the deck is rebuilding the transom up to original height. As you can see it was cut down to set the prop shaft height at 5 inches BELOW the bottom of the hull for FS Class? I may be wrong on that class designation. Only halfway thick part of the entire deck... have to build a wood template to clamp in place and then lay in some layers of biaxial. Oh and lots of holes as you can see......
  11. #83
    checkout that woven roving, my Hydrostream has the same
    but these boats are still around , aren't they
  12. #84
    Jun 2001
    cut a wood block to act as a mold for the transom cut out. Laid in 2 layers of 1708 on the sides and 4 layers on the top, overlapping top and bottom side. All clamped with wood front, back and top to try and make this into a transom shape again. will see how this works out tomorrow.... am sure there will be more work to be done here, but getting a good core is important.
    Attached Thumbnails Attached Thumbnails IMG_1659.jpg   IMG_1660.jpg   IMG_1661.jpg
  13. Likes tnelsmn, W2F a V-King liked this post
  14. #85
    Jun 2001
    after molding....
  15. Likes tnelsmn, W2F a V-King liked this post
  16. #86
    Jun 2001
    transom filling and sanding completed. hope to shot the preliminary primer coat in a day or two....
  17. Likes tnelsmn liked this post
  18. #87
    Jun 2001
    First Primer coat where all the blemishes jump out and say" you missed me !!! "
    Attached Thumbnails Attached Thumbnails IMG_1712.JPG   IMG_1711.JPG   IMG_1713.JPG
  19. Likes tnelsmn liked this post
  20. #88
    Jun 2001
    wellit is white again. Complete with Florida bugs in it.. oh well....gotta love florida the bugshine state
    Attached Thumbnails Attached Thumbnails IMG_1717.JPG   IMG_1720.JPG   IMG_1718.JPG   IMG_1719.JPG
  21. Likes tnelsmn liked this post
  22. #89
    Aug 2015
    NE Tennessee
    Sure looks good!
    Bug or not !!
  23. #90
    Jun 2001
    Test fit of the deck back onto the hull. Established position and fabricated the seat box. Almost look slike a boat again.
    Attached Thumbnails Attached Thumbnails IMG_1760.JPG   IMG_1761.JPG   IMG_1763.JPG
  24. Likes tnelsmn liked this post
  1. Mercury Tech: A 1972 Tower of Power 1150 basket case project
    By Stevewatr in forum Technical Discussion
    Last Post: 05-31-2021, 04:14 PM
  2. Need Help on Restoration Project
    By NoFloat9 in forum Fiberglass and Composites Discussion
    Last Post: 05-28-2011, 07:56 AM
  3. New winter project 1972 Alisson 16r
    By unclebuck134 in forum General Boating Discussion
    Last Post: 09-07-2010, 01:09 PM
  4. restoration project
    By outboards4life in forum General Boating Discussion
    Last Post: 09-09-2002, 09:48 PM
