Results 1 to 12 of 12
    Lindenhurst ,Long Island N.Y.
    Mariner Racing built 2.5
    this is the .044 over motor that was on my Seebold.
    it was sent off to Ruck for a sleeve before its last rebuild.
    it has new pistons,capped wrist pins, all new bearings, new lapped 2 piece sealing rings, decked 7 peddle ( non oiler) front half,efi reed blocks with single stage reeds.
    The ports are matched to 300 drag specs with behind the liner work done as well. The pistons were machined to match the transfer ports.
    it has one of my worked manifolds on it with one of my spacer plates , all complimented by a set of wmh 3 pumper carbs.
    It is fully dressed and topped off with an aluminum flywheel.
    Attached Thumbnails Attached Thumbnails 68D325A0-B5AF-4871-BD15-D98B41E537C9.jpg   CBF4DF65-D3DD-4511-A644-A8424C34909D.jpg   AFE16322-C591-4A79-BCFC-E288014AA821.jpg   FCE56B72-3E4E-45AB-AFBD-7EBF2BB6DDA3.jpg   89541B9F-DD5A-40CD-B81C-600BD50A8C6A.jpg
    B3CA3C8B-9885-4EF8-B04F-0ABD0B0B6C46.jpg   ACA4F531-33F5-4367-8D2B-6A4D34E2BF03.jpeg
    ...................................MARINER RACING
    ...............HIGH PERFORMANCE ENGINE BUILDING AND MACHINING
    ....MAKER OF THE WORLD FAMOUS 1 INCH PLASTIC SPACER PLATE
    ...SPECIALIZING IN 2.4+2.5 CARBURETED AND STEEL BORE MOTORS
    longisland
    nice motor! Hey Jarome good to see your still out there.How you been?
    Hey ... Good to hear from you....
    ive been alright...
    ST.PETE FL.
    5 Thread(s)
    Do you still have your seebold?
    SEEBOLD CHAMPBOAT MERCURY S3000
    My Seebold is long gone
    so is my Activator
    ive been a BIG Boat guy for a while now
    Attached Thumbnails Attached Thumbnails 24BB006D-44ED-41C5-9049-BFD6D9591C54.jpg
    Forgot to mention , there are 0 hrs on the rebuild
    Aug 2016
    Darlington
    How much ?
    Quote Originally Posted by David Jones View Post
    How much ?
    Great question!!!
    $5500.
  9. Likes speedman79, Kcraft liked this post
  10. #9
    Jan 2003
    Bremerton, Washington
    Interested in motor what HP does it make?
  11. #10
    Quote Originally Posted by lumpdady View Post
    Well being that i copied a 300 port map
    i would have a peek at the specs on that motor
  12. #11
    Nice. Early 80's Chris*Craft 35 Double Cabin. Those & the 38 Double Cabins were very popular sellers back then.
  13. #12
    Oct 2018
    Pelham manor
    This is the full motor, with lower? What octane does it run?
  1. XS Series-Custom Built From Mercury Racing.
    By 4-strucked in forum General Boating Discussion
    Last Post: 05-09-2012, 10:23 AM
  2. Boat racing stadium to be built in Missouri
    By jeffbare in forum General Boating Discussion
    Last Post: 12-12-2010, 09:29 AM
  3. 2 decked out motors built by MARINER RACING
    By MARINER RACING in forum General Boating Discussion
    Last Post: 05-31-2005, 07:31 PM
