Results 1 to 15 of 16
    Dunnellon, Fl. / Cincinnati, Oh
    Swing Away Trailer Tongue Hinge
    Anybody use one?
    Thinking of cramming a bassboat into a 20' garage for the winter. Would have to install swing type tongue hinge to do so.
    I have a couple tilt trailers, and don't care for the slop and clunking when driving down the road.
    Wondering how much slop and play one of these has compared to a tilt trailer?
    Thank you for insight!
    Pekin, IL
    The ones I have built have no slop. I am not near pics right now but will see if I can find some tomorrow at shop if you are interested.
    Rock
    Team Junk
  3. Thanks rochelle howell thanked for this post
    A neighbor has one, I asked the same, no complaints from him, but I haven't driven the tow vehicle.
  5. Thanks rochelle howell thanked for this post
    Jul 2004
    Connecticut
    I have one on one of my trailers. There is no slop if you get a well built one.
  7. Thanks rochelle howell thanked for this post
    Wow! Quick responses! Thanx. Thought I'd wait longer being down this far on the list. Any suggestions on manufacturer?
    Pekin, IL
    I have no sperience with manufactured pieces so I can't help you there..
    Rock
    Team Junk
  10. Thanks rochelle howell thanked for this post
  11. #7
    Jun 2018
    Floating around
    I had one that was decent. It had a good size swivel pin, 3/4" or so and two latch pins approx 5" apart. It worked well. Curious to see some of the pics of home designs this is a feature worth learning about because ya never know when space becomes tight again
  12. Thanks rochelle howell thanked for this post
  13. #8
    Jul 2004
    Connecticut
    You are correct, the pin size and the overall quality make a big difference. I'll try and take a photo of what I have as I have a spare that I have not used yet.
  14. Thanks rochelle howell thanked for this post
  15. #9
    Jul 2004
    Connecticut
    This gent took the swing away tongue concept to the next level
  16. Thanks rochelle howell thanked for this post
  17. #10
    minocqua, wis
    Fulton has the good ones bolt or weld on I installed welded one they are tight no play
  18. Thanks rochelle howell thanked for this post
  19. #11
    Jun 2018
    Floating around
    Those fulton look great! The one I had must have been home made or something I looked for pics but couldn't find. It had two latch pins, the swing hitch was slip fit over the tongue for one, and the second looked a like that Fulton one up front if you can picture that? A triangle connection with the pivot being one pin and the catch being two pins. Maybe overkill I dunno its the only one I used and I didnt have it long
  20. Thanks rochelle howell thanked for this post
  21. #12
    Jul 2012
    Lufkin, Texas
    This is on a Mastercraft I have in the shop right now. I’ve pulled it some and it has no slop.
    Josh Peterson
  22. Thanks rochelle howell thanked for this post
  23. #13
    Any name on it?
  24. #14
    Pekin, IL
    Not being critical but how does that thing close. Looks like there is a bolt head in the way unless it goes over top of it.
    Rock
    Team Junk
  25. #15
    Aug 2018
    MI
    Boatmate trailer with a swing away and zero slip clunks or complaints
  1. Cutting the tongue off my trailer...
    By Rgpracer in forum Tow Vehicles and Trailers
    Last Post: 03-20-2015, 07:02 AM
  2. Trailer Hinge
    By grootski in forum Tow Vehicles and Trailers
    Last Post: 08-18-2008, 06:24 AM
  3. trailer tongue extension
    By jtperez in forum Props, Setup, and Rigging
    Last Post: 02-12-2006, 08:13 AM
  4. Swing away trailer tongue project
    By LakeRacer99 in forum Tow Vehicles and Trailers
    Last Post: 11-18-2005, 07:35 AM
  5. Trailer with a bent tongue...
    By mikevr007 in forum Tow Vehicles and Trailers
    Last Post: 10-06-2003, 04:39 PM
