Results 16 to 30 of 35
    Sep 2017
    Ashland city tn
    Quote Originally Posted by W2F a V-King View Post
    The deck on the 2 Checkmates (early 70's 15' and a 16') I restored came off and went back on pretty easy. Mentioning this because if your replacing the core and floor, the transom is a good idea to do now vs later. Adding a set back lift bracket will add some stress to the transom, and if it's old and wood, it could need doing even if you don't see cracks...yet....
    Lifting the deck opens up the boat and makes all repairs easier to do. Doing the transom now with composites and literally tying the transom to the deck and floor/stringers makes it a very strong, never rotting repair. Once and done, and "If" you ever want to repower with more...NO worries, it will be ready for whatever you hang on it.
    Document all your work and "If" you ever sell it, this will help sell it for sure.
    jmo..
    Thanks for gud info. After hrs of reading and examining mine, I know mine needs it all and I have decided to lift deck off, will have roughly 8in set back and modded 2.5 200,
  2. Likes W2F a V-King liked this post
  3. #17
    Sep 2017
    Ashland city tn
    Boat suppose weigh 700lbs. With mod 2.5 say 240ish hp. Is low 90s far fetched?
  4. #18
    Sep 2018
    oh
    James H:
    Pulling the deck is still an option. Thinking recoring center section now adds rigidity to hull for added strength when deck comes off. Starboard flotation box and bolster area wet; so they came out.Attachment 423985
  5. Likes W2F a V-King liked this post
  6. #19
    Aug 2015
    NE Tennessee
    Quote Originally Posted by Merc 2.5 View Post
    I'm not familiar with the predictor and it's hull design. Rigging, prop choice and set up is key to get the most out of any rig. Attention to detail always pays off. My 16' ran mid 80's with a 7 pedal 2.4 almost 30 years ago.
    Picture is a bit fuzzy...old picture from actual film days... It took that much set back to get to air out...and it did!
Name:	My 2nd Checkmate.jpg
  7. Likes nitro_rat, 1954bmw liked this post
  8. #20
    Jul 2012
    Huntington, Texas
    Josh Peterson
    Quote Originally Posted by Danger Mouse View Post
    Well there you have it! The great OZ has spoken...
    leave a message and I'll return your call!
  9. #21
    Sep 2018
    oh
Name:	Checkmate Stringers.jpg
ID:	432857Stringers and frames fitted. 1/2" Bluewater 20 (Coosa). Need to bind the pieces together to give me one inch stringers. Should I use 1708?
  10. #22
    You could, but 1.5 oz mat is all that is needed.
  11. #23
    Sep 2018
    oh
    Any worries with epoxy?
  12. #24
    Mar 2009
    Port Saint Lucie
    1.5 oz mat usually isn't used with epoxy. It will soak in but doesn't break up the binder, so it doesnt like to roll out. But for inbetween 2 layers of coosa should be good.
  13. #25
    Really won't matter what you use with epoxy. Just some epoxy putty will do fine. They do make mat that is epoxy compatible.
  14. #26
    Sep 2017
    Ashland city tn
    How did this build go? Updates pics
  15. #27
    Sep 2018
    oh
    Funny you should ask. Just looked at it again tonight. Plan to epoxy frames and stringers starting tomorrow night. Set it aside for another Checkmate which was seaworthy and had a motor. Last time out got 57 mph at 5400 rpm, and still have about three more inches I can raise the motor. Not time wasted, and back to work!
  16. #28
    Sep 2017
    Ashland city tn
    I've got my predictor bout grinded down and have transom and knees cut , once get stringer and floor cut I'll start glassin mine in , but I still have a paint job to do , new steering and gyages. So hopefully spring for me ,,
  17. #29
    Sep 2018
    oh
    Getting ready to tab in frames and stringers. What should I use for cloth? 1708? Will be using West epoxy.
  18. #30
    Sep 2017
    Ashland city tn
    U got a pic of work. Curious? Mine only had 1 stringer and the floor. was mine a (light layup of sort?) That's the way I got mine ready to go back but would like to c what u have done
  1. 94 Checkmate Predictor Update
    By Go Tast Get Wet in forum Props, Setup, and Rigging
    Last Post: 05-20-2015, 07:43 AM
  2. Checkmate Predictor
    By 87Predictor in forum Props, Setup, and Rigging
    Last Post: 06-06-2011, 10:49 PM
  3. Checkmate Predictor Help
    By kalugs22 in forum Props, Setup, and Rigging
    Last Post: 09-09-2009, 11:25 AM
