Results 1 to 10 of 10
10-29-2018, 10:10 AM #1Member
- Jul 2016
- Finland
- 37
Mirage plus, cupping for bow lift?
Hi. Going to repair my trashed mirage plus spare prop and need some advice and pictures of your mirages with added bow lift.
11-01-2018, 09:50 PM #2Member
- Dec 2006
- Central Wisconsin
- 81
- 7
I dont have pics but added cup towards the tips of the blade always helps....could have a shop add rake to the blades also. Oh and cutting the flare off the end of the barrel had been known to help bow lift also
janihei thanked for this post
11-02-2018, 01:51 AM #3Member
- Jul 2016
- Finland
- 37
I have heard about the flare cut bu I am afraid to do it because the slip is already high at cruising speed
11-02-2018, 12:27 PM #4Member
- Dec 2006
- Central Wisconsin
- 81
- 7
Cup and a sharp trailing edge are important to keeping slip under control...also Mirage props typically don't like to be surfaced
11-02-2018, 01:05 PM #5Member
- Jul 2016
- Finland
- 37
My prop shaft is 5.25-5.5" under the bottom, its not so high for go fast boat but in 3100lbs inboard cuddy cabin like my old chris craft it is bit high for 3 blade. I just want to add some cup to the mirage and give it a try because I have to repair it anyvway. I also have revolution 4 20" and bravo 1 22". It is winter in Finland right now so have to wait till next Summer to test 4 blades. Im just afraid that prop shaft as deep as mine i will loose too much top end with 4 blade.
11-02-2018, 02:03 PM #6
Are used to run the cup on my choppers almost around to the leading edge . You had to visualize how the water runs off the blade and not have the blade cuts through the water. Worked well for ski racing.
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
11-02-2018, 07:24 PM #7Member
- Dec 2006
- Central Wisconsin
- 81
- 7
Ive heard people put lipstick or something similar on the blades then run the prop...the part if the blade doing all the work will be clean. Then they cut and mod the prop from there. I think thats how a lot of cut choppers came to be. Never tried it myself but would be interesting.
11-03-2018, 07:12 PM #86000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Closing up any pvs to just what you need when running below can also reduce slip and add lift. They will still vent some and soften the up swing reducing lift. Will also correct the lean if you have it and run on plane at less rpm.
The four blade might slow you but due to stern lift mainly.
I imagine your your looking for pioltability. More cup typically improves mid range performance but steals rpm and maximum top end.
11-04-2018, 03:31 AM #9Member
- Jul 2016
- Finland
- 37
Stock mirage plus works great at higher speeds put creates poor bow lift at cruising speeds, because it cant handle much positive trim before blow out.
11-04-2018, 03:44 AM #10Member
- Jul 2016
- Finland
- 37
Prop cupping for surfacing....Questions?
By olboatman in forum Props, Setup, and RiggingReplies: 3Last Post: 04-30-2015, 12:45 PM -
looking for a quote on cupping
By afr in forum Props, Setup, and RiggingReplies: 2Last Post: 06-11-2012, 08:30 PM -
Prop Cupping
By DANA ARNETT in forum General Boating DiscussionReplies: 14Last Post: 11-01-2002, 10:12 AM -
Pitch vs cupping
By roxin in forum Technical DiscussionReplies: 5Last Post: 04-07-2002, 10:40 AM
