Results 1 to 6 of 6
Thread: 300R vs 300sx Weights
10-23-2018, 06:33 PM #15000 RPM
- Mar 2015
- Vancouver, Washington
- 131
- 13
- 41
- 24
I would like to know if anyone has weighed a 300Xs 20in shaft with sportmaster and prop? I would want gear lube in the lower unit. The quart of oil in the resivour or what every it holds in the cowl, then I could add the remote resivor weight for a grand total.
Then I would like to know what the 300R actually wieghs with all the oil in the crank case, lower unit with oil and 5 blade 15" wheel.
According to Mercury Literature the 300xs weighs 505. The 300R weighs 312? If I actually had both motors in front me would the total packages really only be 7 lbs different? I know this has been discussed somewhere else, but I don't feel like there was any real conclusion.
Go ahead and throw out your guesses, and when some one posts the facts, you can be the winnerWhitney Woolard
Oregon/Washington
'96 Allison XB2003 w/Mercury 2.5 260ss
10-23-2018, 06:41 PM #2Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Wildman knows
10-24-2018, 05:58 PM #35000 RPM
- Aug 2018
- On a racetrack or at the lake
- 148
- 21
- 52
- 22
Post 15 is a 250R...
http://www.bbcboards.net/showthread.php?t=925606
10-24-2018, 06:36 PM #45000 RPM
- Mar 2015
- 131
- 13
- 41
- 24
Ok, so the 250R is 564 lbs.
How much does the 300xs weigh with lower unit. Mercury says 505 lbs. Can anyone confirm that?Whitney Woolard
Oregon/Washington
10-24-2018, 07:16 PM #5Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
It is more than 505lbs if someone has put it on a fish hook.
10-24-2018, 07:22 PM #6Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
20' backcountry 300sx props
By Jupiter83 in forum Props, Setup, and RiggingReplies: 5Last Post: 08-23-2013, 03:15 PM -
Mercury Tech: 300SX and analog tach and temp
By Go Time in forum Technical DiscussionReplies: 4Last Post: 08-19-2011, 08:49 AM -
4th year anniv of my 2007 30 Skater, T/300SX
By appsyscons in forum General Boating DiscussionReplies: 0Last Post: 04-13-2011, 12:52 PM -
300sx or 280 hmmmm
By R.I.P. in forum General Boating DiscussionReplies: 29Last Post: 09-14-2009, 12:40 PM -
New 300SX
By avit in forum Technical DiscussionReplies: 1Last Post: 05-30-2007, 09:34 AM
