Results 1 to 6 of 6
    Mar 2015
    Vancouver, Washington
    300R vs 300sx Weights
    I would like to know if anyone has weighed a 300Xs 20in shaft with sportmaster and prop? I would want gear lube in the lower unit. The quart of oil in the resivour or what every it holds in the cowl, then I could add the remote resivor weight for a grand total.
    Then I would like to know what the 300R actually wieghs with all the oil in the crank case, lower unit with oil and 5 blade 15" wheel.
    According to Mercury Literature the 300xs weighs 505. The 300R weighs 312? If I actually had both motors in front me would the total packages really only be 7 lbs different? I know this has been discussed somewhere else, but I don't feel like there was any real conclusion.
    Go ahead and throw out your guesses, and when some one posts the facts, you can be the winner
    Whitney Woolard
    Oregon/Washington
    '96 Allison XB2003 w/Mercury 2.5 260ss
    Wildman knows
    Aug 2018
    On a racetrack or at the lake
    Mar 2015
    Ok, so the 250R is 564 lbs.
    How much does the 300xs weigh with lower unit. Mercury says 505 lbs. Can anyone confirm that?
    Whitney Woolard
    Oregon/Washington
    Jul 2004
    Connecticut
    It is more than 505lbs if someone has put it on a fish hook.
    Jul 2004
    Connecticut
    These folks did it properly, interesting post. 564lbs for a 250R all in. Merc is always "gilding the lilly" I guess!
    Quote Originally Posted by volfan#10 View Post
    Last weekend, we weighed the new Mercury 250R V8 engine with calibrated digital scales suspended from an overhead crane. The engine was filled to the required oil level; however, no battery cables, harnesses, or cowling were attached. The engine weighed 534 lbs and the cowling (weighed separately) was 30 lbs. That's a grand total of 564 lbs when fully configured and a bit heavier than Mercury's advertised weight of 505 lbs. Given this, it is suspected that Mercury was weighing the engine minus the lower unit which would most likely result in approximately 505 lbs. It appears this is the same weighing process Mercury used for the 2.5 race engines years ago.
  1. 20' backcountry 300sx props
    By Jupiter83 in forum Props, Setup, and Rigging
    Last Post: 08-23-2013, 03:15 PM
  2. Mercury Tech: 300SX and analog tach and temp
    By Go Time in forum Technical Discussion
    Last Post: 08-19-2011, 08:49 AM
  3. 4th year anniv of my 2007 30 Skater, T/300SX
    By appsyscons in forum General Boating Discussion
    Last Post: 04-13-2011, 12:52 PM
  4. 300sx or 280 hmmmm
    By R.I.P. in forum General Boating Discussion
    Last Post: 09-14-2009, 12:40 PM
  5. New 300SX
    By avit in forum Technical Discussion
    Last Post: 05-30-2007, 09:34 AM
