Results 1 to 4 of 4
Thread: Tach Fluctuation
10-23-2018, 11:15 AM #15000 RPM
- Nov 2016
- Geneva, Florida
- 106
- 12
Tach Fluctuation
I have 260 with brand new Livorsi tach and it fluctuates 200-300 rpms when I'm running. Can anyone give me an idea what might cause this?
10-23-2018, 04:39 PM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
Replace rectifier
Jay @ JSRE
10-24-2018, 05:11 AM #3
I agree, start with rectifier and also check your ring terminal on grey wire. Just had one that was broken but held in place by shield.
10-26-2018, 04:41 AM #4
Switch it to the other side of the rectifier.
If it the problem goes away, you know that one side of the rectifier is bad. Then replace rectifier.Markus' Performance Boating Links:
Tach died- any way to test signal to tach with volt meter?
By CircleHook in forum Technical DiscussionReplies: 12Last Post: 09-14-2014, 05:49 AM -
Voltage Fluctuation and Over Charging
By whays in forum Technical DiscussionReplies: 3Last Post: 07-11-2005, 01:25 PM -
rpm fluctuation
By skater24 in forum Technical DiscussionReplies: 8Last Post: 10-13-2004, 05:44 PM -
Tach Fluctuation
By vector mike in forum Technical DiscussionReplies: 4Last Post: 08-23-2002, 04:39 PM -
Pee stream fluctuation
By Burke Kilgour in forum Technical DiscussionReplies: 20Last Post: 07-22-2001, 01:35 AM
