Results 1 to 10 of 10
    May 2007
    STL
    250 getting ready to breath better
    Finally going to see if dbr250 flash can add excitement
ID:	421387Click image for larger version.
    [IMG][/IMG]
  2. Likes Will hedrick liked this post
    Dec 2013
    georgia
    Subscribed
    Do you have before results
    What stage kit do you have and cost
    Apr 2006
    Eagle River Wisconsin
    Just did this to my 300 but I won't be able to run it until spring.... Interested to see what your gains are!
    May 2007
    STL
    I drove a 300 with 1.62 gears and one without, both on properly setup Xb21’s, and holeshot and
    acceleration are very noticeable. Just hoping my 250 has similar added quickness
    [IMG][/IMG]
    Apr 2017
    Pomona ny
    Was thinking about doing the same to my 250xs but all the mixed reviews have me second guessing if it's worth it. Keep us posted
    Feb 2003
    Bellingham, WA
    Please do post the results when you have some, thanks
    22' Activator w/ 250xs Merc Opti, back home again
    May 2007
    STL
    Weather has not been great, hoping to get out tomorrow for a bit...
    [IMG][/IMG]
  9. #8
    May 2007
    STL
    So it was cold windy and damp so I couldn’t push the boat hard. Holeshot was solid but not life changing different. I can tell it is better because if I the boat wanted to lay on its side of trimmed all the way under up trim didn’t seem to keep up as well.
    I ran a prop i could put on the limiter before and turned similar rpms at a more conservative trim number so I think there is likely an extra mph in ideal conditions but I didn’t go for it today with the wind and no chase boat.
    i think the kit for the 300 had a more noticeable gain
    [IMG][/IMG]
  10. #9
    Apr 2017
    Pomona ny
    Even though it's your cowl it made me cringe a little seeing that window pic. More power to you I don't think I'd have the heart to make those cuts but then again its all in the name of more power
  11. #10
    May 2007
    STL
    It comes with a nice faceplate...
    [IMG][/IMG]
  1. Does removing air silencer help engine breath better?
    By Valero2.5 in forum Technical Discussion
    Last Post: 06-24-2014, 10:08 PM
  2. Question for Hydrotec 92 150 Pro V How well does it breath?
    By Chuck_Nj in forum Technical Discussion
    Last Post: 06-23-2007, 07:28 PM
  3. Help my motor breath!
    By fft in forum Technical Discussion
    Last Post: 10-13-2006, 10:12 PM
  4. The Frankenrude Takes Its First Breath!!
    By Instigator in forum General Boating Discussion
    Last Post: 06-27-2003, 12:44 PM
