Results 1 to 6 of 6
10-21-2018, 11:28 AM #1
Thrust washer and nut kit small shaft
Brand new kit and can have the used washer
$65 shipped
10-21-2018, 08:54 PM #2
My bad.. I meant to respond on this post not the hub. If this is still available I'll take it. Thanks
1986 Hydrostream Voyager XT Merc 260 (Howard Pipkorn signed)
1997 DR 20 Merc 260
10-22-2018, 07:12 AM #3
It is, I sent you the PayPal information on a private message
11-02-2018, 07:53 PM #4
Washer kit
1997 DR 20 Merc 260
11-02-2018, 08:20 PM #5
Shipped .. info will be pm to you
11-12-2018, 01:29 PM #6
Merc Sportmaster Lower unit "Fat Shaft" use a thrust washer or Not?
By weebz69 in forum Props, Setup, and RiggingReplies: 4Last Post: 05-30-2012, 06:31 PM -
Thrust washer, Spacers etc. for Merc.19 spline prop shaft
By David Johns in forum Props, Setup, and RiggingReplies: 5Last Post: 08-09-2010, 03:56 AM -
Thrust washer for small shaft Merc and Mazco RE 4
By TheRickster in forum Props, Setup, and RiggingReplies: 4Last Post: 09-22-2005, 12:51 PM -
Small Hub Laser 2 Thrust Washer ?
By BOOTS in forum Technical DiscussionReplies: 1Last Post: 10-21-2004, 08:47 PM
