Results 1 to 5 of 5
Thread: Merc 2.5 Electronics
10-21-2018, 05:41 AM #1Member
- Jul 2007
- Bermuda
- 93
- 18
- 9
I'm about to pick up a 2.4l 200 powerhead, and the guy said he has a 2.5 with a blown piston minus the electronics he will throw in for a couple hundred bucks. (both carb motors)
Can I use the electronics off the 2.4? or what's the chances getting 2.5 electronics cheap?
10-21-2018, 06:51 AM #2
You can use the 2.4 electronics on the 2.5.
10-21-2018, 08:13 AM #3
Yes my 2.5 has all 16amp 2.4. Also prob sheds little weight
10-21-2018, 02:12 PM #4Member
- Jul 2007
- Bermuda
- 93
- 18
- 9
Thanks guys. My plan is to run the 2.4 and modify the 2.5. Still want to find a second set of electronics but just incase I don't in time I'll use my current 2.4 ones.
10-22-2018, 05:39 PM #55000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
I have a full set of electronics from a 1995 2.5 carbed 175hp. Guaranteed to work as the engine seized due to a main crank bearing failure. I also have older stator, switch boxes and trigger if interested in cheaper older electronics that still work. I forget the small differences between the 175 and 200, not sure if it will work or if it is even any different.
6/4/2017 2 CDI switchboxes $60
6/13/2017 CDI Stator(40 amp) $250
8/22/16 2 rectifiers(voltage regulators) $60
6/15/17 CDI Trigger, $95
Everything else pictured (except for trim relays) Free, might be a few more things not in the picture just ask.
2.5 merc electronics
By suprmag225 in forum Misc. Parts and AccessoriesReplies: 4Last Post: 08-12-2018, 06:31 PM -
Merc Electronics
By 91eagle in forum Technical DiscussionReplies: 1Last Post: 03-15-2018, 09:42 PM
