Results 1 to 10 of 10
10-20-2018, 01:41 PM #15000 RPM
- Mar 2015
- Vancouver, Washington
- 131
- 13
- 41
- 24
Water Pressure to High Need a little help
I am really frustrated and need to reach out for some help. I have a fresh Jay Smith built 260, on a Jay Smith drystack adapter plate. I have been having trouble getting the water temp above 100 degrees. My water pressure with my last sportmaster at 99 mph was 20-25 lbs. I recently purchased an new sportmaster and welded up the starboard water inlet, and was excited to go out and run it. I did and at 88 mph the water pressure was 30-35 lbs. I was scared to go any faster cause the gauge was almost pegged.
My first solution will be to allow more water out of the adapter plate to decrease pressure, but this will most likely decrease the water temperature, which is already, in the "cold zone"
I have already increased the outlet at the poppitt cover to 1/2"
below is a link to motor at idle. You will see two 1/2" hoses from adapter plate with 15/64" restrictors, the heads have stock restrictor washers, and the Poppet plate hose with Half inch hose with no restriction. Pressure is about 2lbs at idle, but rises to 35 lbs at 88 mph.
Any ideas or thoughts would be helpful. Thanks in advance
https://youtu.be/WkmSwQdwBPE
Whitney Woolard
Oregon/Washington
'96 Allison XB2003 w/Mercury 2.5 260ss
10-20-2018, 01:46 PM #25000 RPM
- Mar 2015
- 131
- 13
- 41
- 24
Is it possible that I have a water pump that is creating to much water flow for the rest of the system? I have run six different lower units and the standard 200 cases, seem to produce acceptable water pressures, with a Bob's cone, or Titus Cone. I guess what I am asking is there a combination of parts that would create a flow and pressure that would be to much? It just seems that the amount of water going through the motor is way to much.
Whitney Woolard
Oregon/Washington
10-20-2018, 01:52 PM #3
Are you sure the gauge is accurate? You can test it with an air regulator output on a compressor.
Cervelo777 thanked for this post
10-20-2018, 02:56 PM #45000 RPM
- Mar 2015
- 131
- 13
- 41
- 24
10-20-2018, 03:09 PM #5
Have u tried smaller head restrictor? Smaller Washers to slow down the water?
10-20-2018, 07:20 PM #6Supporting Vendor
- 11,838
- 163
- 11
- 795
With every JSRE drystack system we install/deliver we supply 5 restricter plugs , 2 large, 2 small and a blank so the water temp in the block can be manipulated in tandom with the ambient changing cooling media , mixing plug opening sizes to gain desired block temps , the only issue I had along with this customer we couldn’t reel in was the high pressure readings , the accuracy of the pressure gauge was always in question in my mind ... I’ve found that high pressure numbers on a accurate pressure gauge will normally point to a restriction of spent water leaving the block causing to much heat , with this situation we are seeing elevated pressures and cold block temps ???? Which doesn’t add up IF the pressure gauge readings are valid and correct .
JayLast edited by Jay Smith; 10-20-2018 at 07:25 PM.
Jay @ JSRE
10-20-2018, 08:18 PM #7
Forgot to suggest checking the temp gauge too..... any time you see an odd problem, all the tools used to check it should be checked too.
10-20-2018, 09:22 PM #85000 RPM
- Mar 2015
- 131
- 13
- 41
- 24
I should mention that Jay Smith has spent way more time on the phone with me answering every question about anything I wanted to ask. His customer service is above and beyond anything I ever expected, so i hope that it Jay did not feel that I was pointing any finger at him. To be honest I have called him so many times, I felt bad bothering him again, he has always taken time to get my little brain marching in the right direction. I tested my water pressure gauge today as Flabum suggested, and believe that it is reading 15 lbs. to high, and will order another one Monday. I also feel that my temperature gauge may be lying to me as well. Again, thank you for your patience with me and all the help.
Whitney Woolard
Oregon/Washington
10-20-2018, 09:29 PM #9
Jay will get u straightened out
10-21-2018, 08:54 AM #10Supporting Vendor
- 11,838
- 163
- 11
- 795
Thanks Whitney,
i try to go the extra mile with all engines we build and target total satisfaction with any motor I build . As a rule of thumb If there isn’t a creditable or any gauge to validate temperatures I find if you can hold your hand on the top of the head and hold it there comfortably for an extended time it pretty cool ,if you can hold it there for say 3-5 seconds before it’s becomes too hot to stay there it’s just about correct . I realize That’s not scientific at all , I would always opt to use a temp gun or temp stick to take all the guess work and check calibration accuracy of temp gauge to concur correct / accurate block temps , water pressure gauges need to be tested to validate its accuracies also , one must start with accurate data to reach any conclusion .
Good luck ,
JayJay @ JSRE
High Water Pressure After Changng Water Pump
By maineidyl in forum Technical DiscussionReplies: 8Last Post: 08-11-2018, 05:10 PM -
Mercury Tech: High water pressure & low water temp
By njj502 in forum Technical DiscussionReplies: 158Last Post: 10-19-2017, 03:00 PM -
Water pressure too high with CLE
By wired247 in forum Technical DiscussionReplies: 15Last Post: 06-02-2014, 12:42 PM -
Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
By sasquitch in forum Technical DiscussionReplies: 23Last Post: 07-31-2010, 09:16 PM -
Mercury Tech: To High Water Pressure
By Ripnfool in forum Technical DiscussionReplies: 5Last Post: 10-05-2009, 09:34 AM
