Results 1 to 3 of 3
    Oct 2018
    Block temperature port and starboard
    I have a 200 EFI and I have noticed that the starboard side of the block seems to run a little warmer when idling before the thermostats open up is this normal or do I have a problem???
    Jan 2008
    SUMMERVILLE S.C.
    normal...i usually see up to about 10 degrees difference in head temps
    Oct 2018
    Thanks that's about the temperature difference that I have noticed.. once there is good water pressure and thermostats are open there seems to be considerably less difference in temperature from one head to the other..
  1. Port 20 degrees hotter than starboard ?
    By WATERWINGS in forum Technical Discussion
    Last Post: 08-16-2007, 09:19 AM
  2. ID port from starboard pistons
    By 150aintenuff in forum Technical Discussion
    Last Post: 01-06-2006, 11:02 PM
  3. Counter on port or starboard
    By johnny24 in forum Technical Discussion
    Last Post: 04-02-2004, 11:04 AM
Eddie Marine - Horizontal
