Results 1 to 12 of 12
    Sep 2017
    Miami
    Testing the Allison Grand Sport with a Mercury 150 four stroke
    Preliminary testing and where this project is going. Better results than I thought out of the box. Got some work to do to get it where we want it, but promising.
    https://www.wavetowave.com/home/2018...-a-mercury-150
    Jun 2001
    Crosslake, MN
    Cool project. Keep us posted.
    I love that picture of the yellow Grandsport / 150 Promax - talk about a framer !!!!
    MDS
    Jul 2007
    Delray Beach
    White and black Allison
    10 mpg is pretty impressive.
    Oct 2005
    savannah,ga
    Good article.Good numbers too. Thx.
    St. Cloud, FL
    Cool project. Let me know if you need a driver. Ha!
    2006 Spectre 24' SCS
    2020 Mercury 300 ProXS
    2001 Allison XB2003
    2006 Mercury 250XS
    1988 22' Velocity (sold)
    1995 Allison Grand Sport (sold)
    1998 Mercury Stock 2.5-260 SS
    1990 Velocity 30' - 502's (sold)
    Go Daddy Go! Racing
  6. Likes Michael J Giesler liked this post
    Winnipeg
    that black and white GS is awesome!
    Allison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
    Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
    RIP RPM RACING
    RIP GTS1
  8. Likes WavetoWave liked this post
    Sep 2017
    Miami
    Looks like I made a mistake in the article, when looking to order the upper mounts, the ProXS mounts are different, and stiffer than the SeaPro mounts.
    Sep 2017
    Miami
    So we have run our Grand Sport with a stock Merc 150 four stroke, and so far so good. We upgraded the upper mounts to the ProXS mounts, and they are a small improvement. Best was 72 MPH at 5570 RPM with a stock 28" promax prop. We need low water pickup to get it higher, and can probably squeeze a couple more out of it. That's our first step. Will look at solid mounts, and ECU upgrade after. The goal is 80 MPH with minimal modification.
  11. Likes Great East Predictor liked this post
    St. Cloud, FL
    Quote Originally Posted by WavetoWave View Post
    Was this a different run than the article? If so, you went up almost 200 rpm's but didn't increase the speed. Anything else change besides the mounts?
    How much setback does that hydraulic plate provide? And do you know where you are height wise with the stock case? Engine height makes a huge difference on these boats, so if you cone the case with lwp, it should make quite a difference. Have you tried any 3-blade props yet?
    Good luck!
    2001 Allison XB2003
    2006 Mercury 250XS
    Go Daddy Go! Racing
    Sep 2017
    Miami
    Quote Originally Posted by Ziemer View Post
    Good luck!
    The only other difference was the prop. The first run was Darris' prop, a modified Promax he had laying around. This one was mine, stock promax.
    The Allison plate is 5.5, and we have 2.5 spacer. That run was about 1" below, maybe 1 1/4 if I remember correctly. Water pressure was dropping though, so didn't want to push it. I am doing the lower first, but I'm not with the boat right now, so it will have to be in January probably.
    Hoping to get my Trophy on it to try before I pull the lower unit off.
  14. #11
    Aug 2009
    With your motor that low you might get close to your goal by just raising the motor. I went from 5/8 below to a 1/8 above the pad and saw a nice increase when I was playing with setups on mine
    Sep 2017
    Miami
    Quote Originally Posted by Honda92 View Post
    Ya, definitely. Just being mindful of the water pressure right now. Especially the Promax prop, likes to be really high.
  16. Likes Honda92 liked this post
  1. Allison Grand Sport set-up
    By LakeRacer99 in forum General Boating Discussion
    Last Post: 10-17-2007, 09:12 AM
  2. Grand Sport-Euro-SS2000-T4 w/conservative power? Possible 4 stroke?
    By Stoker1 in forum General Boating Discussion
    Last Post: 01-07-2006, 01:45 AM
  3. Allison Grand Sport???????????(HELP)
    By fasteddie in forum General Boating Discussion
    Last Post: 06-07-2001, 09:58 PM
