Results 76 to 90 of 181
11-18-2018, 04:39 PM #76
11-18-2018, 04:48 PM #775000 RPM
- Mar 2016
- cincinnati, ohio
- 662
- 142
- 32
- 278
- 191
1 bys are there to hold the three transom pieces together, they will be removed later, right????
11-18-2018, 05:00 PM #78
11-18-2018, 06:06 PM #79
First post in the thread has a few motor pics.
mrichartz thanked for this post
11-18-2018, 06:18 PM #80
11-18-2018, 07:51 PM #81LETS GO BRANDON.... LETS GO BRANDON
'84 Checkmate Convincor
AZMIDLYF liked this post
11-19-2018, 05:44 PM #82
Things have been going so good I think I might be someone else.
Got four layers in, gonna put the final 1700 bi-directional on tomorrow and start building my gunnel knee panels.
Transom is getting stiffer than ..... well it's getting there.
warm resin just works better. (it's even winter in CA)
wet out 1700, clamp on layer 3.
all layers are glassed 2" over and returned to hull.
getting ready for number 3
#3 went well set up by the time we got back from lunch. (I think I'll put on #4)
screws seem to pull # 4 in adequately
# 4
Count em ... 4 layers, 4 layers glass, 5th layer 1700 bidirectional to finish tomorrow.
I like the way everything went, don't know if I'd ever use wood in a boat again.Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
11-19-2018, 06:01 PM #83
FUJIMO
The Historic Photo Master
Join DateJan 2004LocationFloridaPosts14,217Thanks (Given)0Thanks (Received)454Likes (Given)0Likes (Received)4177Mentioned2 Post(s)Tagged0 Thread(s)
Originally Posted by NICE PAIR
Tell me more about the high density foam.
brand ?
can I layer it to get the curve my transom has ?
specs on density/weight ?
any problems with epoxy resin ?
...120 lb density is nice for transom foam. you pick the brand. the core is not where the strength is mostly, it comes from the laminate on both sides of any stringer, tranverse stringer, bulkhead, transom, etc. I've purchased hundreds of thousands of dollars worth of CoreCell. same with DivinyCell. so I recommend them, but any PVC foam will do that you can get. it all bends & can be vacuum bagged in place. before use, drill a lot of random 1/8" holes in the foam for air/bedding compound escape. Epoxy is fine but vinylester works well too.
Thanks for your input, NP
Yo Fugimo! Thank-you for steering me towards the foam for the transom, I'll probably never use wood again.Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
11-20-2018, 06:36 PM #84
11-21-2018, 04:56 PM #85
11-22-2018, 06:06 AM #86
You do nice work...........
NICE PAIR thanked for this post
11-22-2018, 09:33 AM #87
11-22-2018, 02:57 PM #88Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
11-23-2018, 09:40 AM #89Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
Not strong nuf for that V4 60 .... better go down to a 280 merc.....looking real good.
11-24-2018, 05:23 PM #90
The one that started it all-
By JPEROG in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 06-10-2016, 05:30 AM -
Mercury Tech: Just getting started.
By boatmann in forum Technical DiscussionReplies: 5Last Post: 04-28-2010, 09:14 PM -
all new but never started
By jersdeal in forum Jet Boats, V-Drives and Stern DrivesReplies: 3Last Post: 11-14-2009, 09:08 AM -
All done but getting started.
By Damyankee in forum General Boating DiscussionReplies: 9Last Post: 12-16-2008, 08:02 AM -
Please Help, cant get 2.4 XRi started...
By JimG in forum Technical DiscussionReplies: 8Last Post: 05-10-2002, 04:38 AM
