Results 46 to 60 of 181
10-29-2018, 02:29 PM #46The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
Divinycell works. H-60 or H-80. Remember, its more about the glass. Make seat boxes from it too if needed. Use small aluminum backing plates to through-bolt anything. PyHi type access holes strategically located for through-bolting & reaching in to glass.
NICE PAIR thanked for this post
10-29-2018, 05:06 PM #47
10-29-2018, 05:10 PM #48
tux974 liked this post
10-29-2018, 10:06 PM #49
Sheet aluminum works great for floors to. I put flipping decks on a lot of Jon boats with old street signs, light and never rots.strong with proper bracing.
10-30-2018, 08:17 AM #50
tux974 thanked for this postWill hedrick liked this post
10-31-2018, 05:01 AM #51
11-01-2018, 05:54 PM #52
11-02-2018, 05:10 AM #53
I like the beginning of extra support! Im guessing transom and knees supports for the PAIR for power next.....
NICE PAIR liked this post
11-02-2018, 06:03 PM #54Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
Shuda Just cut a Stream for it's bottom.....I think I have a Bronze prop for that motor.... with slim case....will look if you want.
11-02-2018, 06:40 PM #55
11-02-2018, 09:10 PM #56Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
Don't wait for me..... It's somewhere in one of my 2 1000 foot barns or in the yard some were.....There was a guy that had a G3 with stream bottom and 150 Merc. Think of it as cutting up a G3.......I was Beating a V4 rude case apart one day....Don't ask why....Ok I will tell....The 2 long studs were stuck.... The prop shaft Broke.... like glass. High tenseil I guess. They use small prop/ pitch cause they have 20/23 ratio. gears. You are doing a big job on that boat.
11-08-2018, 09:26 AM #57
11-08-2018, 09:32 AM #58Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Foam is soooo much nicer to work with than plywood. I won't use wood anywhere in anything I build and haven't since the 80's.....I got spoiled real quick when foam got easier to find. Your old boat will be better than new...
11-08-2018, 10:01 AM #59
11-09-2018, 06:51 PM #60
I'm going to gusset the side gunnels to the new transom and reduce the transom width by 2 feet. Should make quite a difference.
Couldn't find intake screens for old Johnrudes so, a little brass kick plate material an old plastic screen for a template ...... 235,000 holes later ..... homemade carb screens.
Fiberglass material & resin should be here today, next week will show some progress .... I hope.Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
The one that started it all-
By JPEROG in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 06-10-2016, 05:30 AM -
Mercury Tech: Just getting started.
By boatmann in forum Technical DiscussionReplies: 5Last Post: 04-28-2010, 09:14 PM -
all new but never started
By jersdeal in forum Jet Boats, V-Drives and Stern DrivesReplies: 3Last Post: 11-14-2009, 09:08 AM -
All done but getting started.
By Damyankee in forum General Boating DiscussionReplies: 9Last Post: 12-16-2008, 08:02 AM -
Please Help, cant get 2.4 XRi started...
By JimG in forum Technical DiscussionReplies: 8Last Post: 05-10-2002, 04:38 AM
