Page 10 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 136 to 150 of 181
  1. #136
    Final fit on ladder bar, plate on top will allow pass-thru bolts to a brace on top of the splash well to hold the top of my transom height extension. (Looking for cav plate to be an inch above the bottom)
ID:	425124 Click image for larger version.
ID:	425125 Click image for larger version.
ID:	425126 Click image for larger version.
ID:	425128 Click image for larger version.
ID:	425129 Click image for larger version.
    While waiting for resin to dry I pulled the starter for a new drive, cleaned up the commutator, installed new ring gear. (new ring gear had tooth lead-in reliefs, original did not)
ID:	425131 Click image for larger version.
ID:	425132 Click image for larger version.
ID:	425133 Click image for larger version.
    Does any body remember how simple and how much fun it is to work on these old dinosaurs?
    I had forgotten.
  2. Likes tux974, tnelsmn liked this post
  3. #137
    What's the idea with the electric choke setup. I've only needed to hold choke closed for three seconds to start, then it's on its own unless it's near freezing outside, then an extra second. How fast a heat coil , I see it's dialable.
  4. Likes NICE PAIR liked this post
  5. #138
    Dec 2001
    That tube from the carb to the exhaust plate is how Erude snuck in the turbocharger that fooled Merc guys when racing for pink slips.......And has a highly restive chunk in the exhust cavity to warm up the choke.....probly why they had a rep as gas hogs......X115 exhaust plate had wedges cast in for better flow. You have a mag now set them points......
  6. Likes NICE PAIR liked this post
  7. #139
    Just for kicks, maybe pull those transfer covers and heads. Load the cylinders with cotton balls and file things square.
    Last one I saw running in action was an erude about the same year. Had a mad idle and was chugging back the fuel. Was on a Springbock I think. Long time ago, went real well. Went on plenty of rides in that one, good running boat.
  8. Likes NICE PAIR liked this post
  9. #140
    Dec 2001
    HeeHee..... I say we RAID his shop with cutting tools.......But we might get glass dust so I will pass.....
  10. Likes NICE PAIR, AZMIDLYF liked this post
  11. #141
    Going to be a good looking good running rig
  12. Likes NICE PAIR, tux974 liked this post
  13. #142
    I hoping for a SLEEPER...
  14. Likes NICE PAIR liked this post
  15. #143
    I sure hope the motor fits when it's ready, wait, I gotta do that too. ;-)
    Keel /transom brace fitted, holes drilled.
    Mount template to raise motor 4.5 inches completed. Brace to run from 4 bolts to back of motor plate. (mount plate to be 1/2" aluminum)
    feels like it's gonna work.
ID:	425640 And ..... it only took 2) tries.
  16. Likes tnelsmn, tux974 liked this post
  17. #144
    Dec 2001
    I think your motor bracket is off by 1/8 of inch.....looking good....4.5 might be too high ..... unless....HeeHee.
  18. Likes NICE PAIR liked this post
  19. #145
    Could do a tripod mount for a ski tow now that you're closing in?
  20. Likes NICE PAIR liked this post
  21. #146
    Who'd a thunk.
    Only 50 short years and you have to disassemble the magneto, clean and pack the bearings, adjust the points.
    What ever happened to quality in the workplace?
    I had to make a good one out of two. only lit myself up 4 or 5 times.
ID:	425710 Click image for larger version.
ID:	425711 Click image for larger version.
ID:	425712 "Houston, we have fire"
  22. Likes mrichartz, FMP, 2.5-21 liked this post
  23. #147
    I'm guessing those are solid core wires. I'd check continuity end to end while twisting, bending them gently. The plug end sometimes will wear and need a little cut off and refitted.
  24. Thanks NICE PAIR thanked for this post
  25. #148
    Lol, planned obsolescence wasn't a boardroom strategy yet huh?
  26. Likes NICE PAIR liked this post
  27. #149
    Wondering about those downdraft carbs and plenum to and through the reeds. Must be room for some shaping and stuffing, cages as well. Could probably do some good fine tuning on this motor top to bottom.
    Someone must still have the book on tweaks for this one, like eliminating that heat tube, a bit of port work, the chest signal and down turn to tuner , heads psi, lower exhaust relief above cav.
  28. Likes NICE PAIR liked this post
  29. #150
    Quote Originally Posted by NICE PAIR View Post
    Who'd a thunk.
    You must have felt energized at the end of the day.......
  30. Likes NICE PAIR, tnelsmn liked this post
  1. The one that started it all-
    By JPEROG in forum Ebay Listings and Other Internet Listings
    Last Post: 06-10-2016, 05:30 AM
  2. Mercury Tech: Just getting started.
    By boatmann in forum Technical Discussion
    Last Post: 04-28-2010, 09:14 PM
  3. all new but never started
    By jersdeal in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 11-14-2009, 09:08 AM
  4. All done but getting started.
    By Damyankee in forum General Boating Discussion
    Last Post: 12-16-2008, 08:02 AM
  5. Please Help, cant get 2.4 XRi started...
    By JimG in forum Technical Discussion
    Last Post: 05-10-2002, 04:38 AM
