Results 1 to 9 of 9
    Florence, SC
    Cool LH Sportmaster on a Single Outboard Boat
    Has anyone here run a LH SPortmaster on a Single Outboard boat? I am getting down to the final stages of building my Eliminator for the Parker and thinking of switching to a LH Sporty to take advantage of the big left hand turns on the course. Considering how rough the water is going to be, my thinking is that I could get into the power harder/sooner out of the turns.
    Thoughts?
    Sep 2007
    bay city mi.
    I did on a 21 obsession (21daytona). No problems at all. I didn't race in circles, so I can't comment on that.
  3. Thanks Tango thanked for this post
    You'll have to dig in the rules, but I think they are not allowed...and the counter shaft due to design has a built in fracture point.
    Florence, SC
    2. LOWER UNITS:
    a. Green lower units must remain as delivered from the manufacturer & shall run the propeller shaft no higher than ½” below the last 3’ of the running surface. The prop shaft must be parallel to the running surface at the time of measurement.
    b. Non green lower units may be modified but must be a V6/8 style. No XR6 style units allowed. Shaft height limited to 1” below the last 3’ of the running surface.
    c. All lower units must have a working forward, neutral, & reverse from the driver’s seat.
    Not excluded but please explain a "built-in fracture point" if you will.
  6. Likes kct11 liked this post
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    What? Elaborate please
    I've been running LH lowers for almost 4 decades. Alone and in twin and triple apps. They don't fail any sooner....
    Folsom, Cal
    seen LH on small 21 tuff/skators
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
    Whatever....carry on..
    Dec 2001
    I agree..... seen Lh lowers go bad...the halve thing gets out of that grove and bad things happen. All lowers break.....the only safe thing is the prop nut.
  1. Single Outboard in Offshore (p-6)
    By mike merola in forum General Boating Discussion
    Last Post: 09-09-2016, 08:23 AM
  2. Best rough water 21-22ft single outboard boat.
    By mrpenguin in forum General Boating Discussion
    Last Post: 07-08-2012, 01:42 PM
  3. What is the best riding/ruff water single outboard boat
    By Fast-Trukin in forum General Boating Discussion
    Last Post: 10-27-2009, 07:58 PM
  4. Single Outboard Steering options
    By Bullhead Bully in forum Props, Setup, and Rigging
    Last Post: 03-05-2008, 06:50 AM
