Results 1 to 15 of 15
    Netherlands
    How to increase water pressure 3.0 sportmaster
    Hi,
    My 18 ft Hydrostream Virage with 12 inch bob's jackplate and 300xs with 1.62 sportmaster runs the fastest when I jack up till the water pressure drops. When I go up higher speed comes up but then the gardian mode gets in because low pressure. Now I run 109 mph and centerline torpedo approx 1 a 1.5 inch above centerpad. Was thinking to install a transom pickup but think its not worth for the last inch higher because the transom pickup will create drag and only use it for the last few mph. Read that some guys do some mods to their sportmaster so they can jack up higher any ideas or pics what I can do? Saw some pics that they close the 2 starboard water inlets but not sure if thats to increase pressure. I run a 14.75x34 Spinelli dr4 and a 15 x 34 humpback cleaver.
    Boat: Hydrostream virage
    Engine: Mercury 300 XS DBR 1.3
    Props: 32' performance drag4 ,buckshot gen2 4 blade cleaver 34'
    Max speed: 113mph
  2. Likes bullwhipjkg liked this post
    Apr 2006
    Eagle River Wisconsin
    Titus was doing some mods for the sportmaster.. I remember reading a bass and walleye boat artical years ago where they did it on a stroker/300X and they were able to raise the motor higher and pick up several mph. I think they called it the Titus sportmaster mini mod.
  4. Thanks darkdream thanked for this post
  5. #3
    Moline,Ill
    Not mine, just things I've observed
    is gone
  6. Thanks darkdream, NICE PAIR thanked for this post
    Likes darkdream, tux974 liked this post
  7. #4
    Netherlands
    Thanks that's exactly what I mean! My boat will be faster for sure when its possible to jack up higher but think its not worth to add a external water pickup because that will also create drag. So I can drill the water inlet a little longer in the prop direction. If I can jack up a 1/2 inch higher I am already happy
    Max speed: 113mph
    Richland, WA along the Columbia River
    Great topic. water pressure seems to hold me back.
  9. Thanks darkdream thanked for this post
  10. #6
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    Holy Smokes
  11. #7
    Aug 2010
    Barrie, Ontario, Canada
    I saw a real nice water intake modification on a members (JPEROG) lower unit at Jasper that might interest you. Maybe reach out and ask him about it.
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
  12. Thanks darkdream thanked for this post
  13. #8
    Netherlands
    Thanks,
    Want to know if its easy to do myself. Live in the Netherlands (europe) so not easy to ship my lowerunit to the USA for modifying. Dont know whats better for my boat transom pickup or modify the sportmaster
    Max speed: 113mph
  14. #9
    Aug 2010
    The sportmaster mod I saw looked pretty good and effective.
  15. Thanks darkdream thanked for this post
  16. #10
    Netherlands
    Thanks I send a PM to 'JPEROG' really curious if its easy to do
    Max speed: 113mph
  17. #11
    I don't think easy is the correct term but it is effective. The down side is that it raises he danger meter every time that you are running less skeg in the water. Its also hard on propellers.
  18. Thanks darkdream thanked for this post
    Likes NICE PAIR liked this post
  19. #12
    Quote Originally Posted by stealthperf View Post
    Yes, it worked well! Will see if I can find a picture.
    I will agree with Joe. Be very careful because it can lose steering, break a skeg, prop shaft or a blade when running hard high.
    Twin applications is much more forgiven.
    Be careful!!
  20. Likes NICE PAIR liked this post
  21. #13
    Feb 2014
    Missouri
    What I see in one pic of the motor running is you have nosed out of the swell. I’m not sure more setback would help though as you would just be moving the whole unit and not changing drag forces. I did expect to see more roster tail though something like a drag boat at that speed. Looks good just expected more and I like flat tails. I imagine you have tried trim/ angle of attack changes. Looks like mods is what’s left.
    All I have seen was filling in the groves and adding skeg
  22. #14
    Dec 2010
    Denmark
    Thumbs up
    hey,
    I ran in to some sea wheed which clogged up my cooling water intake, and this made my day compleetly different. Therefore I did a second intake including a filter, an dit works quite fine. See my photo album.
    https://www.screamandfly.com/album.php?albumid=2528
    and Youtube.
    https://www.youtube.com/watch?v=7SF0HzfFCaM
    And because it actually sucks water this way, must make better water pressure at the other side. Because less suction power is required. And I belve the drag is less than the traditionally intakes.
  23. #15
    Netherlands
    What you guys think will it make some difference in water pressure if I just drill the holes a little longer to prop direction? Because of the shape of the lower the inlets will be a little deeper then stock. Or will it have some downsides in handling and performance? Still didn't made a decision what I will do with my lower only looking for holding presure so I can jack up a little higher.
    Max speed: 113mph
  1. Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
    By tristanlee85 in forum Technical Discussion
    Last Post: 07-02-2018, 10:59 PM
  2. Sportmaster High water pressure / Flow
    By inspectorlance in forum Technical Discussion
    Last Post: 07-13-2009, 10:00 AM
  3. Mercury Tech: How to increase fuel rail pressure on 3.0 Liter Merc
    By Stitch King in forum Technical Discussion
    Last Post: 07-09-2008, 01:41 PM
  4. No water pressure on Sportmaster
    By RedVegas91 in forum Technical Discussion
    Last Post: 06-05-2005, 11:20 PM
