Results 1 to 7 of 7
Thread: Tilt trim wireing
10-07-2018, 03:25 PM #15000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
Tilt trim wireing
I have newer style controls 1999 to a 1980 225 merc the pump wires are red blue and green I have blue/white green/white and 2 browns that where hooked up to tilt trim on side of motor anyone ever hooked up this way before?
10-07-2018, 06:59 PM #2
Blue and green are all you need to make trim work.
RockTeam Junk
10-07-2018, 07:39 PM #35000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
10-07-2018, 09:38 PM #4
I am assuming the big red and black wires are coming off the solenoids, not the pump and if so you are correct. Red pos. and black neg. The other three wires are red pos. blue to blue (or blu/white) and green to green. The wires in your hand are the blu and green. Brown and tan are not necessary for the trim to work.
RockTeam Junk
10-07-2018, 10:18 PM #55000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
10-08-2018, 07:17 AM #6
Does not matter where you get the 12v. I would not use a purple wire as it is 12v key on.
RockTeam Junk
10-08-2018, 08:29 AM #75000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
Aftermarket trim: Panther power trim and tilt bracket opinions?
By mxz in forum General Boating DiscussionReplies: 4Last Post: 10-28-2016, 06:05 AM -
wireing up a teleflex trim guage to a 2.5 merc
By ultranutz in forum Technical DiscussionReplies: 9Last Post: 07-18-2012, 09:20 PM -
OMC Tech: 2-piston trim system won't TILT up, but WILL trim up
By pcrussell50 in forum Technical DiscussionReplies: 2Last Post: 08-20-2010, 03:41 PM -
1500xs merc tilt pump wireing
By eautosales in forum Technical DiscussionReplies: 2Last Post: 06-13-2002, 09:19 PM -
"Need help with merc trim pump wireing"
By stoneman in forum Technical DiscussionReplies: 3Last Post: 04-23-2002, 01:01 PM
