Results 1 to 7 of 7
    Sep 2016
    haliburton
    Tilt trim wireing
    I have newer style controls 1999 to a 1980 225 merc the pump wires are red blue and green I have blue/white green/white and 2 browns that where hooked up to tilt trim on side of motor anyone ever hooked up this way before?
    Attached Thumbnails Attached Thumbnails E09B9F7D-7E5A-4624-AA0D-D12060170687.jpeg
    Pekin, IL
    Blue and green are all you need to make trim work.
    Rock
    Team Junk
    Sep 2016
    haliburton
    Quote Originally Posted by rock View Post
    Rock
    OK so the red wire coming off the pump is not needed to be hooked up to anything? it has big red wire im asuming for positive power and big black wire for negitive power then 3 wires coming off it red,green,blue. Just dont want to blow anything
    Pekin, IL
    I am assuming the big red and black wires are coming off the solenoids, not the pump and if so you are correct. Red pos. and black neg. The other three wires are red pos. blue to blue (or blu/white) and green to green. The wires in your hand are the blu and green. Brown and tan are not necessary for the trim to work.
    Rock
    Team Junk
    Sep 2016
    haliburton
    Rock
    Yes big red and big black go to solenoids. Thanks for the help can i just put the small red to the positive on the battery? or any positive lead?
    Pekin, IL
    Does not matter where you get the 12v. I would not use a purple wire as it is 12v key on.
    Rock
    Team Junk
  7. Thanks jaybrown thanked for this post
    Likes jaybrown liked this post
    Sep 2016
    haliburton
    Rock
    ok thank you
  1. Aftermarket trim: Panther power trim and tilt bracket opinions?
    By mxz in forum General Boating Discussion
    Last Post: 10-28-2016, 06:05 AM
  2. wireing up a teleflex trim guage to a 2.5 merc
    By ultranutz in forum Technical Discussion
    Last Post: 07-18-2012, 09:20 PM
  3. OMC Tech: 2-piston trim system won't TILT up, but WILL trim up
    By pcrussell50 in forum Technical Discussion
    Last Post: 08-20-2010, 03:41 PM
  4. 1500xs merc tilt pump wireing
    By eautosales in forum Technical Discussion
    Last Post: 06-13-2002, 09:19 PM
  5. "Need help with merc trim pump wireing"
    By stoneman in forum Technical Discussion
    Last Post: 04-23-2002, 01:01 PM
