Results 31 to 34 of 34
Thread: Witch is stronger
10-09-2018, 07:14 PM #31Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10931
Best I have found over the years is a Divinnycell HS-80 core or equivalent foam core in either 1/2'' or 5/8'' thickness with a corebond adhesive bedding and combined with 1708 glass wet out with vinylester resin like a reichold 100. There may be better glass weaves, but the 1708 is more than adequate for most small boats.
W2F a V-King, NICE PAIR liked this post
10-18-2018, 07:48 PM #32Team Member
- Lake Coochiching, Ontario
- 7,705
- 269
- 472
- 1541
- 6 Post(s)
You'd gain more with more glass on the outside of the 3/4"
10-19-2018, 11:15 AM #33The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
a rubber squeegee is your best friend for distributing the resin over the top of a laminate, like 1708. you work the resin to the end of the laminate & push it off into a small container & you can then pour that back onto somewhere else that needs it. this gets rid of the glossiness(excess resin) in a laminate, and gives the very best smooth finish. excess resin in/on a laminate is the enemy. it makes a lamination more brittle. when I look at someones boat being laid up & see a bunch of excess resin(gloss), it tells me they are not the best laminators. the "rubber" squeegee material in the bottom right of the photo, NOT(never use) a Bondo spreader...
XstreamVking, NICE PAIR liked this post
10-19-2018, 11:19 AM #34The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
this is the best "rubber" squeegee material...
Mercury Tech: which would be stronger and faster
By 985Coonass in forum Technical DiscussionReplies: 5Last Post: 06-21-2018, 12:02 PM -
What is stronger for surfacing
By neveredge in forum Technical DiscussionReplies: 7Last Post: 06-25-2013, 12:17 AM -
Safer ?....Stronger..?...Need opinions...(pic)
By WATERWINGS in forum Technical DiscussionReplies: 17Last Post: 11-15-2012, 02:42 AM -
Stronger Eyesight?
By INXS in forum The Scream And Fly LoungeReplies: 20Last Post: 11-11-2004, 08:55 AM
