Results 1 to 2 of 2
10-04-2018, 09:27 PM #1Member
- May 2014
- Tampa, FL
- 56
Heavier outboard / hull weight balance?
Hi everyone, I've been researching in reference to boat / hull balancing and can't find much info. I wonder if there's a way to balance a hull with extra weight in the transom from a heavier outboard? Will adding weight in the front balance out hull to factory specs?
23' concept / Merc 150 @430lbs (factory rated up to 225 @505lbs)
Repowering thoughts: Verado 4 stroke @635 lbs
10-04-2018, 09:47 PM #2
Most larger hulls will tolerate more weight at the transom. It's the smaller boats (<18') that have the most challenges with larger motors. Really going from the 430 lb merc to the 635 lb verado is equal to one passenger on the back seat. The extra power will more than compensate.
The difference between the verado and the theoretical rated 505 lb motor is even less. Leave the passenger at the dock and maybe move your batteries forward if you have a problem with the extra weight.
Side to side balance is more critical than front to back!Josh Peterson
Weight&balance records
By outasite in forum General Boating DiscussionReplies: 13Last Post: 08-16-2015, 12:50 PM -
Mercury Tech: Rod/Piston Balance - Top to Bottom or Port to Starboard balance or light to heavy
By SAMMYBOY in forum Technical DiscussionReplies: 7Last Post: 05-04-2013, 01:17 AM -
STV Euro...can it handle the heavier XS?
By Fasttoys in forum General Boating DiscussionReplies: 25Last Post: 12-30-2008, 10:11 AM -
balance ? new piston/ rod weight
By skeeter87 in forum Technical DiscussionReplies: 3Last Post: 05-15-2007, 09:21 PM -
New Tune, louder and heavier....
By kevlar in forum The Scream And Fly LoungeReplies: 17Last Post: 12-11-2003, 08:51 AM
