Results 1 to 8 of 8
    May 2014
    Tampa, FL
    Optimax charging issues
    Hi everyone, I have my 2006 Optimax 150 not charging the batteries. This year model has an alternator but I wanted to know if there's other components to check, like an external (apart from alternator) volt regulator or fuses? I've been researching and the info I've come across is mixed with stator system Mercs. Any input will help. thanks
    Just get a new alternator from DB electrical, Less than 100 bucks online, I have bought 3-4 from them all good.
  3. Likes NICE PAIR liked this post
    Jul 2012
    Lufkin, Texas
    I have had good luck with DB Electrical also.
    Josh Peterson
  5. Likes NICE PAIR liked this post
    May 2014
    Tampa, FL
    Ok, I’ll be ordering one. So the alternator has the voltage regulator built in?
  7. Likes NICE PAIR liked this post
    Yep.It's an automotive type with all in one construction. Kill the power before working on it and watch for spacers/washers under the bolts when removing the old one. Some engines have them, some don't. Good time to inspect the belt also. Belts off so spin the compressor pulley to check for smoothness and for wobble of the shaft.
  9. Likes NICE PAIR liked this post
  10. #6
    Feb 2005
    seattle
    there's a 100 amp inline fuse on the output line. i bought a new alt 4 yrs age for $350 so the 100 is a deal.
  11. #7
    Feb 2014
    Missouri
    Yep, other then that is double check connections and battery since they go bad.
    You can practicly take take it to autozone for testing
    just remember the output is ~13 something not 14.7 like a car. They can load test the battery as well.
  12. #8
    Jul 2011
    Gloucester, VA
    Have you tested right at the post on the alt? If you get a stupid crazy 18v reading check the 100 amp fuse. Also check for a signal to the rectifier. Dont just buy new parts to buy new parts.
  1. Mercury Tech: optimax issues
    By rc.chris in forum Technical Discussion
    Last Post: 03-26-2018, 08:44 AM
  2. 2010 optimax issues
    By framquij in forum Technical Discussion
    Last Post: 04-08-2017, 10:06 AM
  3. 1988 xr4 charging issues
    By Chief BDF in forum Technical Discussion
    Last Post: 04-21-2016, 11:10 AM
  4. 99 optimax 150 not charging batteries
    By wenchris in forum Technical Discussion
    Last Post: 08-09-2007, 07:51 PM
