Results 1 to 9 of 9
10-01-2018, 01:17 PM #1
I/o props on outboards. No pvc holes
quick question i just bought a new motor for my 22 Activator. I have a 14” stainless marine setback bracket. I was going to mount my motor 3/4” below the pad. Low water pickup 1.75 ratio
I have access to a bunch of I/o props hydromotive, bravo 1 etc. I was going to borrow them for testing but was wondering how necessary is the pvc holes drilled into the bullet of the hub? What is the impact of not having these. (Don’t think my buddies want their props drilled. Lol )
How does a chopper style prop run on these boats ? I have a 24 and 28p choppers.
10-01-2018, 02:01 PM #25000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
The holes vent exhaust around the outside of the prop, allowing the prop to spin up to an RPM in the motor's optimal power band. Run the prop without and see how it performs. Really depends on the particular boat and prop whether or not it will get a better holeshot with or without
10-01-2018, 04:02 PM #3
Just try them. Smaller pitch might be fine. Worst case is they take a while to get on plane. If you like the prop everywhere else holes can be added to take off better.
NICE PAIR liked this post
10-01-2018, 08:19 PM #45000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
I don’t think you’ll notice the lack of holes once on plane.
I tried some i/o props on my prOgression and other than taking forever to plane they were fine on plane
10-02-2018, 06:07 AM #55000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
Also, chopper style props should run well on an activator 22.
10-02-2018, 07:11 AM #6
Ok thanks for the replies. Yeah I was wondering if the non vented would be luging the engine trying to get on plane. It will be good to get it on plane then see how the props perform and then know what to shop for.
10-03-2018, 02:10 PM #7
Only one way to know, try some.
10-19-2018, 04:36 PM #86000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
You more or less can’t just drop the hammer. A controlled quick hammer drop works better.
Bring it it up to speed and once you hang smothly add throttle to plane out. Takes a few to match.
Vents and full full throttle hammer drops are more fun though
10-20-2018, 10:09 AM #9Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
One of my best props I use for my 26' single o/b hull is a stern drive over hub cleaver. Very low slip and can run it fairly high.
32 bravo props with vent holes
By Classic seacraft in forum PropellersReplies: 1Last Post: 01-03-2018, 05:08 PM -
Bravo 30p 8 vent holes FJ props
By gorillapowered in forum PropellersReplies: 2Last Post: 10-28-2016, 08:48 AM -
What is best product for filling in screw holes and guage holes? Thanks, Mike
By mragu in forum General Boating DiscussionReplies: 11Last Post: 12-31-2013, 08:12 PM -
Casting holes in props.
By stanton in forum Props, Setup, and RiggingReplies: 2Last Post: 11-22-2009, 11:51 AM -
Difference in 2.4 head gaskets? (big holes vs small holes)
By WATERWINGS in forum Technical DiscussionReplies: 3Last Post: 10-18-2006, 08:59 AM
