Results 61 to 75 of 85
10-12-2018, 06:39 PM #61Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Diameter x pitch?
10-12-2018, 08:58 PM #621) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
10-12-2018, 09:19 PM #63
Buddy of mine bought a 27 Concept with twin 225 Opti's on it. Boat would only do 55 out of the box. After raising the engine bracket and the engines, we got her up yo 70. I'm sure we can get more out of her with nthe right props, but have not had the opportunity to borrow different props to try...."One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
10-12-2018, 09:21 PM #64
Don’t we all just wish there was a big rack of props to try before you buy somewhere? Lol
NICE PAIR liked this post
10-12-2018, 11:26 PM #65Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Nope, not allowed
10-14-2018, 02:05 PM #66
New personal best. 60.8mph at 6100rpm. It was real choppy today.
No problem getting on plane. If I went slow to get on plane, it would blow out and I’d have to stop and start again.
The new motor height doesn’t porpoise at 50 anymore, but it now does at 20?! Lol oh well.
With the gps on my phone, I got to a solid 59mph, but saw 60.8 as a max, while hopping still, and trimmed up slightly past neutral. I still had 20psi water pressure at speed.
Dont mind the speed on the dash reading low... my paddlewheel/transducer was kicked up. I need to tighten the bolt to keep it down.
Im thinking a little more height may get more speed, and I might try the 26 pitch prop again.
May have to start thinking of a Bobs nose cone, strictly for a low water pickup on it.
Some numbers:
40mph at 4100rpm
45mph at 4600
60mph at 6100 (hopping/trimmed in choppy water). <- scary to me!
Improvents! I’m going to run it this way for Saturday’s Connecticut river run.Last edited by home made tunnel; 10-14-2018 at 02:08 PM.
10-14-2018, 02:14 PM #67Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Clearance to case good? Maybe a bit higher and 26, need to spin the 6+ if that prop will bite and not get the bow high? Christmas wish list a good four or five blade
10-14-2018, 03:39 PM #68Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
You're going to loose that camera or worse
10-14-2018, 04:05 PM #69
Go to a hull pickup before nose cone. You might need the propshaft to be level with the pad with that setup.
Azure AZ259, 8.1
10-14-2018, 04:16 PM #705000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
I'd like to see a video of what's going on around lower unit and transom at speed. With the motor that high and stock lower unit I wonder how you have any water pressure at all?
10-14-2018, 07:31 PM #71
Yea clearance is good. I ground off another 1/16”. It’s got a gap of a couple credit cards now.
no way... that’s where I started and it ran like crap. I’ve gone a couple inches higher and it has been getting better and better. Why would you say hull mounted over low water pickup nose cone?
me too!!! I need to find a friend with a go pro to mount back there. I think it’s splashing off the sponsons keeping the lower wet. ? Maybe. Idk. But it’s reading pressure regardless lol. Setup continues.
Thoughts on my next try? Up another inch and run the 26” prop?1) 1995 14' Bayliner Restoration <--Click
10-14-2018, 07:41 PM #72
You bought the propshaft a few inches above the pad?
Are you using the stock water intake?
I'm confused a bit...Azure AZ259, 8.1
10-14-2018, 10:14 PM #731) 1995 14' Bayliner Restoration <--Click
10-14-2018, 10:55 PM #74Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Looks like any minute now and you're going to need a lwp or convert it to a Lycoming airboat motor. How much setback?
10-15-2018, 12:56 AM #75
Lol airboat motor.
I have the bobs machine standard manual jack plate... but I just realized I have it set on the 5” setback. I think I’m going to flip it around to the 2.5” setback orientation.
my jack plate: https://bobsmachine.com/product/conv...te-200-hp-max/1) 1995 14' Bayliner Restoration <--Click
