Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    NE Louisiana
    Quote Originally Posted by Callum5009 View Post
    Thanks! Yah it's a 15". It took me and my dad 4 years to build it! Now that it's out of the garage I get to work on my new 60hp!
    It is a 13 or a 15? Cool boat! I love that you and your dad made it a two seater!!!
    https://www.glen-l.com/designs/outboard/tuffy.html
    One thing I would do, is look at a jackplate that would better suit your needs. The only plates I see that Bob's has are way over kill (for 300hp heavy motors), less the 40hp jackplate which isn't enough.... ?
    You can move weight around in the boat that may help. Where are the fuel tank and battery?
    How about some pictures of the bilge when finished? Any running pics?
  2. Thanks Callum5009 thanked for this post
  3. #17
    Jul 2018
    Toronto, Ontario
    I would get power trim but it's a short shaft and they're really hard to find. The best thing I've found is CMC and it's around $600
  4. #18
    Dec 2001
    Put a L brace on the green board. Flatys don't really need setback. Just a good surfacing prop.
  5. #19
    Jul 2018
    Toronto, Ontario
    thanks for all your help guys, I really appreciate it.
  6. #20
    6 inch jack plate with a 60hp twin and you'll be fine, but if your not sure then just add 2 extra knee's and put them up as high as you can and long as you can within reason. you want these about 4 inches outside what will be the bolt holes for the jack plate at the top.. if you dont want to add too much extra weight then cut some large circles out the wood and just seal everything with resin of your choice.. you will have a much stiffer boat with 2 knee's rather than just that small short one on their now. and it will be a stronger transom that could hold a 125hp easy.
  7. #21
    Jul 2018
    Toronto, Ontario
    How bout u tell my dad that��. I wanted to buy a 3 cyl but he was worried about it.
  1. Setback bracket
    By Tripps in forum Misc. Parts and Accessories
    Last Post: 07-24-2016, 04:54 AM
  2. transom bracket setback and 2 jackplates
    By Cary 29 in forum Props, Setup, and Rigging
    Last Post: 05-10-2012, 06:59 PM
  3. setback bracket to transom
    By ck1flyer in forum Props, Setup, and Rigging
    Last Post: 06-27-2007, 07:57 AM
  4. setback bracket
    By fyremanbil in forum Technical Discussion
    Last Post: 08-23-2001, 07:45 AM
