Results 76 to 90 of 293
Thread: 2.5 ff rebuild
10-02-2018, 08:51 PM #76
Freakin fast! Na, havnt a clue
10-03-2018, 10:41 AM #77
10-03-2018, 05:41 PM #78
I received rod today, everything caps up great and is all in. Now I'm gonna go back thru 1 rod at time and and locktite and do torque sequence. Question, should I do the 90 deg or 45, the bolts come from wsm , I noticed some of promarine bolts say 45deg?
10-03-2018, 07:44 PM #79
Chase the threads, clean and dry hole and bolts. Red loctite 271, 35 ft/lbs. No angle BS!
Josh Peterson
Merc 2.5, Laseraddict liked this post
10-03-2018, 08:22 PM #80
Well guys ! Rookie mistake #1. I broke a bolt off in a rod!
10-03-2018, 08:24 PM #81
I had bought a brand new torque wrench , but from harbor freight , it never clicked threads were clean. Seem b working fine til I moved to the 30lb setting and it never got there!
This really pisses me off ! Been long time since I've broke a bolt but I'm not real sure it's my fault. Idk
10-04-2018, 05:18 AM #82
I never understood why mercury says torque and turn another 45 degrees. Why can’t it be a specified torque value?
10-04-2018, 05:22 AM #83Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
H-F Junk
10-04-2018, 05:29 AM #84Josh Peterson
10-04-2018, 06:02 AM #85
Well I need yalls opinion. Should I try get bolt out rod or look for another rod? Not sure if it will come out with the red
10-04-2018, 06:56 AM #86
Certainly try. Did it break off flush?
10-04-2018, 07:03 AM #87
No it hanging out a good ways , you know of a good extractor that mite work? Need a socket extractor thing I believe
10-04-2018, 07:17 AM #88
While ya messin with it, be careful not to get on the cracked cap surface and knock any of the tiny high spots down. Any shiny spots on surface is no good. Also recheck alignment once done. Hope ya get it
10-04-2018, 07:37 AM #89
I may just buy a rod if someone has sum laying around?
10-04-2018, 07:54 AM #90
141’s? Unfortunately only ones I got left are culled ones. Getting harder and harder to get get ones. Bought a set of six awhile back and only three would pass inspection. Pro marine does have some by Sea Pro for $75. They are new and made in Japan. I’ve used a few with issues. On average they weigh a little more than the Mercs and will need to be lightened considerably for high revving situations. I ain’t really put any to test yet performance wise, but this last experiment mota I built has a couple lightened ones in it. So far only turned it 7k because of lean issues, but so far they have stayed in there. We will soon find out, and I’ll let yalll know. In mild situations for sure they are fine.
Rebuild!
By Merc 2.5 in forum Technical DiscussionReplies: 113Last Post: 08-12-2018, 04:49 PM -
best place for powerhead rebuild/lower rebuild on Long Island?
By play2win in forum Technical DiscussionReplies: 2Last Post: 08-08-2011, 01:49 PM -
Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
By Liberator*21 in forum Technical DiscussionReplies: 4Last Post: 10-06-2010, 06:39 AM -
Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
By rickyo in forum Technical DiscussionReplies: 5Last Post: 06-05-2010, 04:08 PM -
Need Rebuild on CLE
By bigmotor in forum Technical DiscussionReplies: 0Last Post: 07-14-2005, 10:06 PM
