Results 1 to 5 of 5
Thread: Svs vacuum pump
09-26-2018, 09:09 PM #15000 RPM
- Jan 2014
- Illinois
- 770
- 12
- 89
- 382
Svs vacuum pump
Wanting to run vacuum pump on drag motor with svs. Curious where selenoid and throttle switch can be ordered. Also if you have picture of how you set it up. Would really appreciate it.
09-27-2018, 05:16 AM #26000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
Get a micro switch from summit for the gas peddle and use an old choke for solenoid. Makes it super easy.
09-27-2018, 04:33 PM #35000 RPM
- Jan 2014
- Illinois
- 770
- 12
- 89
- 382
Where does the selenoid go? In between The T in the line from ecu to svs on svs side of T
09-27-2018, 06:43 PM #46000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
If the ecu is on the powerhead I put the solinoid next to the ecu. The hose from the vacuum pump goes to one side of a tee fitting. The ecu goes to one side of the tee. The last port on the tee goes to the choke solinoid. The last spot on the solinoid stays open to dump the vacuum. Then the fun make of making it start easy and getting the vacuum back into it when you get off the gas so it doesn’t keep flooding the motor.
09-28-2018, 06:44 AM #55000 RPM
- Oct 2004
- umatilla,FL
- 247
- 7
- 45
- 46
if your running a trim timer you can hook solenoid to the timer the digital delay has two separate timers so you can set it for delay and run time.
vacuum pump
By wired247 in forum Misc. Parts and AccessoriesReplies: 0Last Post: 03-08-2014, 07:14 PM -
How much vacuum?
By bigboy in forum Fiberglass and Composites DiscussionReplies: 30Last Post: 10-22-2012, 07:35 PM -
is this vacuum pump suitable?
By pcrussell50 in forum Fiberglass and Composites DiscussionReplies: 15Last Post: 06-08-2010, 09:54 PM -
How to make a cheap vacuum bagging pump
By Bajaha in forum Fiberglass and Composites DiscussionReplies: 22Last Post: 12-18-2009, 12:14 PM -
Everybody knows how to vacuum bag, right?
By Cp in forum General Boating DiscussionReplies: 25Last Post: 11-10-2003, 07:51 AM
