Results 1 to 2 of 2
09-26-2018, 05:23 AM #1
2007 Hydrostream Vegas / Opti 250xs / Hydro Jacker short set back / 28 Trophy
New to me Hydrostream. It's a ski model so it has the bow gas tank.
I've read about this setup with a Mazco 28 but can't seem to find any info on this combination with the Trophy prop. The Trophy I got with the boat needs to be reconditioned so I thought before I went to the expense I'd see what Scream and Fly readers thought.
Thanks in advance.Last edited by TraceF3; 09-26-2018 at 05:27 AM.
09-28-2018, 08:02 AM #25000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
Did you pick up the boat that was in Houston area?
I haven't had a chance (and won't until next summer now) to test out anything but the 26" trophy that came on my boat.
81 with a 2.5xs, 6" set back, just above the pad.
Based on the numbers I read for my particular engine I expected a little more RPM with that prop (I am about 3-400 rpm below the limiter) compared to what others are turning.
Anyway, I found the boat handles best with the prop buried (1.5-2" below the pad, but then I top out at 70-72ish) or dead even/slightly above (80-81ish), in the 1.5 (ish) to 0 range it seems to porpoise more at lower speeds and still runs low 70's on top.
8-10" setback seems to be the sweet spot, I have 6", my motor is a little heavier than most of the vegas out there with 8-10" and a lighter 2.5. I want to try adding 2" more setback next summer.
2007 hydro stream vegas ski boat
By kittenporter2 in forum Hulls up to 20'Replies: 2Last Post: 02-10-2019, 07:53 PM -
Photos: 2007 hydro stream vegas ski boat
By kittenporter2 in forum Outboard and Racing HistoryReplies: 3Last Post: 01-29-2019, 12:39 PM -
By kittenporter2 in forum Hulls up to 20'Replies: 2Last Post: 04-20-2018, 11:05 AM -
By kittenporter2 in forum Hulls larger than 20'Replies: 3Last Post: 04-05-2018, 09:18 PM
