Results 1 to 15 of 66
09-23-2018, 06:35 PM #1
Mercury 200 xri Falls flat on it's face
Took boat for test drive today, first time out for me with it. Went to take off out of and motor came up to around 3500 rpm's and fell flat on it face, then all of a sudden it took off like a bat out of hell and then tach dropped out and motor fell flat on it's face again and then tach came back and motor picked back up, couple times tach never came back but motor picked up and ran. By looking at things it appears to have new regulators(CDI) and new stator...for reference sounded like motor dropped down to around 3,000 rpm's....1995 200 xri...any help appreciated..
Also failed to mention idle stabilizer and detonation box is still hooked up.Last edited by Bruce2; 09-23-2018 at 06:52 PM.
Daddy taught me to never force anything but to just get a bigger hammer.
1995 19'0" Champion bass boat
1995 200 XRI
09-23-2018, 07:34 PM #2
Do you have a multimeter and a DVA adapter? Download the CDI troubleshooting manual and start testing.
http://www.cdielectronics.com/wp-con...g-Guide_RS.pdf
It will walk you through the testing procedures. If you need a DVA adapter, there are cheap ones available on eBay that I prefer to my expensive "tool truck" unit.Josh Peterson
09-23-2018, 08:16 PM #3
09-23-2018, 08:22 PM #4
I would check the "new" CDI parts first...
Josh Peterson
Bruce2 liked this post
09-23-2018, 09:37 PM #5
I don't know the answer...i had a notification asking why i asked for help in here if i knew the answer that's why i said i don't know the answer..i figured the ecu was having issues since it has a new stator and regulators...
1995 200 XRI
09-23-2018, 10:17 PM #6
Start with output tests on the high side of the stator. There are lots of things to cover on these motors too, from the pulse pump to injectors etc. If the pump diaphragms still have black paint on the outsides you are going to want to rebuild that.
09-24-2018, 08:29 AM #75000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
If you leave the tach out of the equation that sounds more like a fuel delivery problem
HavasuDreamin' liked this post
09-24-2018, 08:56 AM #8
09-24-2018, 11:00 AM #9
09-24-2018, 01:53 PM #10
Have had idle stabilizers do weird stuff before. Throw it in the trash and was said stator output tests.
09-24-2018, 02:25 PM #11
Stator output to switch boxes good..but voltage coming out of switch box for left bank 4 5 6 is not so good..even pulling spark plug wire off on those plugs on that bank didn't make no difference. Haven't check yellow wires yet as it started raining and im working outside.
1995 200 XRI
09-24-2018, 02:54 PM #127000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
start with replacing the plugs with the right NGK. i had 3 new motors do the same falling flat and it was a bad champion plug.. then do as suggested above.
09-24-2018, 03:19 PM #13
1995 200 XRI
09-24-2018, 04:17 PM #14
09-24-2018, 04:42 PM #15
Let me back up here for a moment...does one switch box control 1 bank like 2 4 6..? cause that bank is mostly dead when pulling plug wires 1 3 5 make a big difference when i pull plug wires. Pulled 2 plugs out on left bank 4 & 6 and 1 plug out of right bank # 1 the 2 on the left bank look like they have never fired the right bank #1 is blackish looking.
1995 200 XRI
Help, Evinrude falls on its face when throttled
By Krazymaan in forum Technical DiscussionReplies: 31Last Post: 06-21-2016, 09:55 AM -
OMC Tech: 85 150xp new rebuild falls on its face.
By jb94z in forum Technical DiscussionReplies: 19Last Post: 06-20-2014, 08:24 PM -
Another hull question, how flat is flat?
By BenKeith in forum General Boating DiscussionReplies: 4Last Post: 10-04-2002, 07:36 PM -
falls on its face
By Tom in forum Technical DiscussionReplies: 10Last Post: 08-09-2002, 09:19 AM -
200 falls on its face
By Bassman in forum Technical DiscussionReplies: 8Last Post: 06-03-2002, 09:48 AM
