Results 1 to 2 of 2
    Jul 2008
    Canada
    Setting throttle travel and idle issue
    So having some idle issues. I can’t seem to get this thing adjusted properly.
    Does anyone have any pictures of where everything should be lined up? As in the cams? Also there was a screw missing. The one at the top of the butterfly that holds it on the cam. The engine was running but the the butterfly kept getting sucked shut. So I just put in a screw, not sure how that should be aligned. Should the screw go all the way though the butterfly arm?
    I put an order in for the tps test lead harness. I went through the manual but I can’t really figure out the process to get the linkages all aligned properly.
    Jul 2008
    Canada
    Oh... it’s a 2002 225 efi with the downdraft intake.
  1. Setting issue?
    By Fl Boy in ILL in forum Computer and Forum Support
    Last Post: 12-30-2011, 07:00 AM
  2. Setting idle
    By crewchief18 in forum Technical Discussion
    Last Post: 08-01-2011, 08:05 PM
  3. idle setting adjustment
    By leapingtigr in forum Technical Discussion
    Last Post: 06-15-2007, 10:44 PM
  4. Setting the idle RPM on a 93 2.5 260
    By Markus in forum Technical Discussion
    Last Post: 07-01-2003, 12:06 PM
  5. 98 JohnRude200---setting the idle
    By A.J. Pastwa in forum Technical Discussion
    Last Post: 08-28-2002, 08:29 AM
