Results 1 to 2 of 2
09-23-2018, 08:28 AM #15000 RPM
- Jul 2008
- Canada
- 112
Setting throttle travel and idle issue
So having some idle issues. I can’t seem to get this thing adjusted properly.
Does anyone have any pictures of where everything should be lined up? As in the cams? Also there was a screw missing. The one at the top of the butterfly that holds it on the cam. The engine was running but the the butterfly kept getting sucked shut. So I just put in a screw, not sure how that should be aligned. Should the screw go all the way though the butterfly arm?
I put an order in for the tps test lead harness. I went through the manual but I can’t really figure out the process to get the linkages all aligned properly.
09-23-2018, 08:28 AM #25000 RPM
- Jul 2008
- Canada
- 112
Oh... it’s a 2002 225 efi with the downdraft intake.
Setting issue?
By Fl Boy in ILL in forum Computer and Forum SupportReplies: 9Last Post: 12-30-2011, 07:00 AM -
Setting idle
By crewchief18 in forum Technical DiscussionReplies: 1Last Post: 08-01-2011, 08:05 PM -
idle setting adjustment
By leapingtigr in forum Technical DiscussionReplies: 1Last Post: 06-15-2007, 10:44 PM -
Setting the idle RPM on a 93 2.5 260
By Markus in forum Technical DiscussionReplies: 17Last Post: 07-01-2003, 12:06 PM -
98 JohnRude200---setting the idle
By A.J. Pastwa in forum Technical DiscussionReplies: 5Last Post: 08-28-2002, 08:29 AM
